Results 1 to 3 of 3
Thread: Brakes and Rim sizes
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Default Brakes and Rim sizes
    Hey Guys,
    Just after some advice regarding Brake and rim sizes, planning to do an upgrade on the vs for track days events,
    At the moment ill be running 16" rims on it daily, so this should be fine for the 298mm rotors, however the 322mm VE VE upgrade is only a little extra - which i wouldnt mind getting, would i able to fit 322mm rotors behind 16" rim? i know the VE run a 16" rim so dont see why not (ebay says 17" minimum?). these are the kits in mind if someone could shed some light
    VR VS COMMODORE FRONT BRAKE UPGRADE KIT TO 298mm DISCS - eBay Discs, Brakes, Car, Truck Parts, Cars, Bikes, Boats. (end time 16-Oct-10 20:49:05 AEDST)
    VR VS COMMODORE FRONT BRAKE UPGRADE KIT TO VE SPECS - eBay Discs, Brakes, Car, Truck Parts, Cars, Bikes, Boats. (end time 16-Oct-10 20:49:07 AEDST)
    Power is measured in DECIBEL
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    Quote Originally Posted by SweetWagon View Post
    Hey Guys,
    from what i have seen you will not fit the larger brakes behind 16s i helped another forum member do the VE upgrade to his VS ute and they barely fit behine the 17s im pretty sure theyre the larger ones, NOT_AN_ABBA_FAN sells these kits(i think he still does) you might get a more detailed response from him
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    Feb 2009
    longford, victoria
    Hey Guys,
    my geminis
  1. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  2. rim sizes
    By MOE87 in forum General
    Last Post: 31-12-2005, 10:55 PM
  3. Rim Sizes
    By Shounak in forum General
    Last Post: 15-12-2005, 12:21 PM
