Results 1 to 13 of 13
Thread: Cleaned inlet manifold expansion chamber NOW CAR WONT RUN!
    vn series 1 g/f`s car vt seies 1 98
    Apr 2010
    Default Cleaned inlet manifold expansion chamber NOW CAR WONT RUN!
    Hi all i have just cleaned out the inlet manifold chamber on top of the motoe it is now clean but i believe i may have got gunk down into the inlets and now the car wont run whwnever i try the car coughs and splatters and sometimes backfires i`m a bit worried to try again as i`m worried about the damage backfires may cause
    ANY IDEAS HOW TO GET IT TO RUN
    i have tried to clean with a vac but no help any help would be great
    thanks in advance
    shaggs
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    You haven't knocked a vacuum line off by chance?
    Could be a coincidence also, you're ignition leads/plugs might be stuffed.
    VH SS
    May 2009
    Toowoomba, Qld
    not sure what you mean by inlet manifold expansion chamber ?
    I see that you have a VN & your g/f has a VT. I assume you are talking about the VT if you are referring to an expansion chamber ?
    VT has the ecotec engine with the removeable top on the intake plenum
    if so, make sure the rubber seal that seals top plate to the plenum is sealing correctly
    also make sure all the connectors are back on, vacuum lines etc
    Apr 2010
    Sorry guys yes its the vt v6
    so even with shit falling in it it while i cleaned it (i`m thinking maybe pieces are too big that may have fallen in pieces of carbon n black crap) it should run not mis n stall?? even in this case???
    will trying to start it repeatedly while it misses and backfires slightly do it any damage as i`m hoping if i try to start for 10 mins or so with injector cleaner in it and a little spray or two of throttlebody cleaner may clear it out????but i dont wanna damage it
    thanks again
    shaggs
    VH SS
    May 2009
    Toowoomba, Qld
    depends how big the carbon pieces were...
    if they were fairly sizeable, a piece may have got stuck between an inlet valve and the seat, leaving the valve partially open when the valve closes. Which can result in a backfire/miss.
    Check all the hoses, connections and make sure that plate is sealing. Failing that, I'd be trying some top end cleaner, to see if you can flush the carbon pieces out of the intake ports
    VS S-Pack SII
    May 2008
    if i was running well before... then you have forgotten something... even small peices of carbon/crap falling down will do nothing dramatic... they will just get sucked in and blow out through the exhaust....
    Like the guys say... check all vacuum hoses, think back to pulling it apart... what did you disconnect??? the idle air valve... did you touch the plug on that? the throttle body, did you unplug anything on that?
    if you STILL cant find anything... do a diagnostic check on it... the computer will tell you a code, and from that, you can see where the problem is...
    Apr 2010
    nah man big pieces maybe even possibly as big as a 50 cent but not shure how big and or which ports it went down........or how much
    so spraying a fair bit of throttle body cleaner down inlets then reseal quickly and try to fire maybe this will clean the crap out definatley did not disconnect anything and all seals are good but each time it back fires badly it pops off the vac hose or some hose that runs from a solonoid near the front firewall on drivers side it pops off right near the throttle body
    shaggs
    VH SS
    May 2009
    Toowoomba, Qld
    I've seen a piece of carbon wedged into a valve seat, preventing a valve from sealing. It had obviously been there for a long period of time as it had left a small depression in the valve seat and valve face. The valve seat had to be reground and the valve replaced
    If an intake valve is sticking open or not sealing properly, it will cause a backfire through the intake.
    Shaggs, I doubt carby cleaner is going to do anything to dislodge the carbon (if that is the problem)
    See if you can find some 'top end cleaner' and run it through the intake - make sure it's EFI/O2 sensor friendly. Not sure who makes it now (maybe Wynns ?). I know Toyota used to sell some awesome top end cleaner. Not sure if they still do.
    Lesson to be learnt here.... never let crap fall into your intake ports, stuff some rags into the openings should you decide to clean the intake again - just remember to pull the rags back out when finished!
    VT
    Apr 2005
    QLD
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    make sure you havent sprayed cleaning solvents on your idle air control valve, it can damage them.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    Apr 2010
    oh i just went hack with it
    didnt think about efi or injectors but i done this with my vn no worries but i had to spay from the throttle body as u cannot separate that one hope i havent damaged the idler i did ruin this one before on my vn even using efi safe air flow meter sensor cleaner sorry for the spelling i`m not checking as i`m in a big hurry i`m trying to get the car running to go riding!!!!
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Maybe try some of the Subaru Engine cleaner stuff ive used it a few times, thats if carbon is the problem, what do u mean u cant separate that one from the throttle body?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Apr 2010
    HA HA............. the secret is hold ya foot to the floor while trying to start, once revs make 3,500to 4,500 hold for 5 secs slowly decrease then the car will idle i was trying to get it to start pretty much by just turning the key once foot was held flat it started then blew it all out the back end!!!! gently releaed the pedal and all good as new thanks for ya help
    shaggs
  1. VR wont start after inlet manifold gasket change
    By muddyjunior in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2010, 07:39 PM
  2. VT V6 Top End. Heads, Intake manifold, Plenum chamber, Throttle body.
    By VSO.38 in forum Parts And Other Items For Sale
    Last Post: 23-11-2007, 03:55 PM
  3. V8 wont start after replacing inlet manifold gaskets
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2007, 08:20 PM
  4. taking off plenum chamber/inlet manifold VT V6
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2007, 11:52 AM
  5. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
