Results 1 to 9 of 9
Thread: t700 and 4l60e extension housings ...information needed
    VH Sl wagon and vr executive t5
    Dec 2009
    Default t700 and 4l60e extension housings ...information needed
    hey guys i hope this is the right thread and hasnt been asked before. ...i want to know is it possible to put a t 700 extension housing on a 4l60 e so that i can run the vn type speed sensor because it has the provision for a cable to be put in as opposed to a 4l60 that runs a reluctor wheel set up.. reason i ask is because i want to put an ecotec v6 and 4l60 into a vh and want to keep original speedo and i figured that if i could change the housing and relevant insides . (to go from reluctor wheel to gear set up) and run a VDO inline speed sensor and cable jobbie??? make sense
    thanks in advance
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the 4l60e ecu uses the speed signal from the same sensor and wont work with the t700 sensor output you would have to run some kind of convertor box .the t700 threadedd peice comes out just like the 4l60e and fits in but the trigger wheel has straight cut gears instead of angled so you can just fit it and go you need to swap the cog on the output shaft
    Dec 2009
    y wont the sensor work?because vn is 10 pulses then divided by 5? and the vs is 4 ? i think ....could you please rephrase wat you said as im not sure wat your sayin......r u sayin that i can just unbolt both housings and just put the t700 gear inside the 4l60e and use the t700 extension housing? i was goin to use a vdo vss to cable job installed on the vn extension housing ? as the vn runs a cable type speed sensor and the vs runs a reluctor??
    sorry for not understanding what you meant
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the 4l60e uses a 2 wire sensor and the t700 uses a 3 wire.they both put out different waveforms ones squarewave output the other i cant remember of hand think its sine wave .depends what your sensor/cable drive adaptor you have as to what ouput its putting out.fitting the t700 sender into a 4l60 they just fit right in theres the screw thread to screw cable on but then behind that its held in with 1 small bolt and the whole threaded part comes out just like the 4l60e sender does.so all you really need to do is swap the cog on the output shaft.
    Dec 2009
    so i need to run a vs speed sensor so how can i do this???? but i need to run a cable aswell........im having a hard tme picturing wat your talking about ....my bad :-( ...your patience is probably wearing thin but i would apprecitate it if you could help me out ... tell me what you would recommend doing in this situation as i just cant se wat your talking about ..... doent the vn screw onto the housing and the vs slides in and is retained by a bolt ?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    both slide in like that just the vn one has a cable fitting on it
    Dec 2009
    oh ok .....my bad....so could you please explain wat the difference is between sine wave and square and why it would make a difference
    . i am unsure what the adaptor pulses as i havent got it and i couldnt find it on the net either
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the computer wont read the signal coming out the sender which will stop it controlling the auto .so you need either the right kind of sender output on your cable adaptor,or you need to get a convertor box to convert the output to what the ecu wants to see
    Dec 2009
    thanks so much mate muchly appreciated
  1. O2 Extension harness
    By MickT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-05-2010, 04:27 PM
  2. T700 Auto Service Kit same as 4L60E?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2008, 07:53 PM
  3. WTB: VP Calais/VQ Statesman Strut Housings
    By Nevyn in forum Swap / Wanted to Buy / Trade
    Last Post: 12-09-2008, 10:58 AM
  4. T700 wiring connections - help needed
    By Barclay in forum Electrical Wiring / Questions
    Last Post: 29-11-2007, 09:59 PM
  5. extension of warranty
    By rivalta_mn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2005, 10:16 PM
