Results 1 to 5 of 5
Thread: vt 5Ltr with no spark!!!!! help!
    VY II SV8
    Oct 2010
    Near Gawler
    Default vt 5Ltr with no spark!!!!! help!
    few probs with me car, wouldn fire up, the fuel pump in pumping and all the rest, engine is turning over but there's no spark... At first the car did start then died as we went to drive off then died and hasnt fired up since. Doesnt seem to be any spark going to the dizzy.... does that mean coil is shagged?
    VY II SV8
    Oct 2010
    Near Gawler
    I checked the lead from the coil to the dizzy, no spark. Ive replaced the coil and still no spark comming from the coil but power going into the coil. Anything else i should check for????
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    Another dud coil?.. Try swapping out your ignition module as well see if that works.
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    VQ 5L - 12.6@108 stock bottom end & comp
    Sep 2006
    VY II SV8
    Oct 2010
    Near Gawler
    we changed over the ignition module and that was the problem. car runs again!!!!!! thanks for all ur help
  1. need help vs 5ltr no spark and hoow know about the manual computers
    By bigjimy87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2011, 08:08 PM
  2. Spark Plug leads Vk 5ltr
    By Sik_Cordz in forum V8 Development and Modification
    Last Post: 05-03-2008, 08:15 PM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
