Results 1 to 5 of 5
Thread: T5 Manual Short Shift
    1992 VP Holden Berlina V6
    Nov 2010
    Rockhampton
    Default T5 Manual Short Shift
    Hi
    I'm wondering what I need to make the throw of the selector shorter for my vp v6 manual. I don't mean shortening the length of the selector but the distance of travel the stick moves between 1st and 2nd, 2nd-3rd etc etc. I know a ripshift allows the stick take shortcuts between gears via angles from 2nd-3rd and 4th-5th but I want to know what makes the selection between gears shorter so that the gear stick doesn't have to travel so far. I work as a mechanic and we have cars in our workshop with short throws but no one at work can explain how the setup works. any help appreciated
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    The fulcrum point is changed to give a lesser mechanical advantage. This is how the knob on the shifter can move a shorter distance yet have the same travel on the shifter linkages. This is also why they are typically a firmer shift that takes a little more force. Basically comes down to leverage points.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    i made my own short shifter. Used a 20mm thick plate of billet ally and machined the holes into it. It spaces the entire pivot point of the shifter 20mm higher. I then used some steel rod welded in to extend the length of the 'rod' that goes into the gearbox. Bolt it all down with new longer bolts and hey presto, budget short shifter!
    Beats payin $400 for a rip shifter, cost me about $30. Mite not have the positive stops and the spring into 3rd, but i never miss the 3rd shift anyway
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    GTP 85's Avatar
    Aug 2006
    Quote Originally Posted by maldotcom2 View Post
    Do you have any pictures?
    i dont unfortunately cause it's in the car lol. It definitely shortens the throw by heaps. Both my cars have T5's, going from one to the other (other being the one without) it seems almost twice the distance between gears.
    If you can score a spare shifter.. the part that bolts into the gearbox.. turn it upside down and look at the imprint the gearbox leaves on the lid... Basically you need to make a sandwich plate to fit snug in there between it and the gearbox. Need a hole of course so the rod can pass thru.
    Pretty straight forward if you have basic mech skills. Rule of thumb... the exact thickness of the plate also needs to be added to the rod
    hope it makes sense
  1. Short shift kit?
    By vzhauler in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-09-2009, 08:22 PM
  2. Short Shift Kit - VP
    By xlr8_87 in forum V6 Development And Modification
    Last Post: 30-05-2006, 09:42 PM
  3. Short shift for VT?
    By bsbozzy in forum V6 Development And Modification
    Last Post: 28-04-2006, 09:59 PM
  4. short shift
    By kacriss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2005, 07:55 PM
  5. Short Shift in V6?
    By gonadman2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2005, 09:36 PM
