Results 1 to 8 of 8
Thread: where to buy a solid flywheel & clutch kit for v6.....Reccomendations ?
    vs ute
    Dec 2010
    Launceston Tasmania
    Default where to buy a solid flywheel & clutch kit for v6.....Reccomendations ?
    who is a good supplier of a solid flywheel and clutch kit
    good quality and well priced to suit ecotech v6 running 5 spd getrag?
    cheers fellas
    VS L67
    Sep 2007
    BrisVagus
    I highly recommend NPC Performance Clutches: Home.
    Be aware though, putting a billet flywheel in front of the GETRAG will make the box sound a LOT louder.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    Vy Ute, V6, Manual
    Mar 2009
    East gippsland Vic
    vs ute
    Dec 2010
    Launceston Tasmania
    Quote Originally Posted by Decicrate View Post
    Thanks for the answer , when you say a billet flywheel , does this extra noise come from any solid flywheel behind a getrag ( Billet does that just mean solid )? i ask because the getrag already is known for its whining and i dont know i want that to be any worse lol
    Quote Originally Posted by brodiewilson View Post
    i recommend
    VT VX VY SIX CYLINDER HEAVY DUTY CLUTCH WITH FLYWHEEL (eBay item 220703621115 end time 29-Dec-10 11:49:51 AEDST) : Cars, Bikes, Boats
    they will probably also knock the price down a bit if you don't buy through ebay but directly through thier store.
    Mate that looks like a good one, im not sure i would go heavy duty as im not keen on a real heavy clutch, might ask if they do a standard one too, although heavy may be suited better to my supercharged 3.8 ?
    cheers for the answer mate
    vs ute
    Dec 2010
    Launceston Tasmania
    i recommend
    vs ute
    Dec 2010
    Launceston Tasmania
    VS L67
    Sep 2007
    BrisVagus
    Billet basically means it is made from one piece of material. The dual mass has a rubber dampener to help quieten the noise of the box.
    It is not a whine as such, more of a rattle. It is usually worse at idle in neutral, when the box is warm.
    The GETRAG uses a hydraulic system to operate the pressure plate, so even when you use a 'heavy duty' setup, the load on the clutch pedal is still reasonably light.
    When you say supercharged 3.8 are we talking aftermarket or factory?
    vs ute
    Dec 2010
    Launceston Tasmania
    its just the factory supercharger. the engine is from a 3.8 statesman
    just how bad is this extra noise? is it worth worrying about?
    thanks
  1. Clutch Kit for Solid Flywheel
    By uNEEk in forum GSL RallySport
    Last Post: 27-07-2011, 01:15 PM
  2. Do NOT get a solid flywheel put in a manual VT
    By JoeFish in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2010, 03:48 PM
  3. VS V6 Ute 99 Manual - DMF to solid flywheel?
    By shasam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2010, 11:16 AM
  4. [NSW] Exedy HD Clutch kit V6 Getrag Solid flywheel
    By Swordsy in forum Parts And Other Items For Sale
    Last Post: 14-09-2009, 04:17 PM
