View Poll Results: 20'' rim on VT yes or no
Voters
9. You may not vote on this poll
  • yes
    5 55.56%
  • no
    4 44.44%
  • never
    0 0%
  • maybe
    1 11.11%
Multiple Choice Poll.
Results 1 to 17 of 17
Thread: are 20'' rim legal on my VT 97 Commodore in nsw
    VT commodore Club sport kit
    Jan 2011
    mildura
    Default are 20'' rim legal on my VT 97 Commodore in nsw
    just purchased a VT with 20'' rims some say I con not register the car with these on it
    VR SS
    Sep 2010
    If I remember correctly you can go 1" wider and 2" bigger diameter from standard wheel size
    Anything bigger will require a mod plate
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    Did you get an engineers report with the car for the wheels?
    Or you could just change to stock rims for the rego to make it easier for you
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    VY 3.8
    Nov 2010
    Maroochydore
    Just go to the nsw transport website and check out the modification guide. No point on getting peoples opinions cause they are not always right. Up here in qld we can put any size rims on as long as the overall tyre diameter is no more then +15mm or -26mm.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    1. There is no 2" rule. Its all about rolling diameter and I'm 95% sure you can only do 15mm more than biggest factory fitted to model.
    2. There isn't a 20" tyre in the profile you will need that will have the correct load rating on it.
    3. Tyre cannot foul any body parts including inner guards when it's turned from lock to lock. Haven't seen a single VT with 20's that manages this.
    Short answer, there isn't any way you can legal put 20's on a VT - VZ that doesn't involve getting it engineered.
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    ive got 20s on my VX SS
    and ive got 245/30/R20s and they make the overall rolling diameter 11.8 mm bigger then normal (from memory, i think thats fine?)
    the load rating of my car is minimum of 93V, my tyres are 97W.
    and lock to lock i dont scrape. at all.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    jesus tap dancing christ, go to the vicroads website and search it.
    Fairly sure its 20% larger then the largest factory fitted wheel.
    VT being 17x7.5 means you could probably at a rough estimate go to a 19x8 and get away with it. But do your maths properly.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by john369 View Post
    are you registering the car in nsw or vic?(seeing as your profile lists as mildura)
    Guidelines for Alternative Wheels & Tyres (Australia)
    read this thread, click the link, then read the pdf.
    VY 3.8
    Nov 2010
    Maroochydore
    See what I mean about taking peoples advice... Heaps of different opinions and they are all different...
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by Daggy082 View Post
    This guys got a point!
    JShaw's Avatar
    JShaw is offline greeeeeeeeen
    06 VZ Executive
    Dec 2010
    South East Melbourne
    not really sure about the whole 2" rule, i'm fairly sure it is upheld in vic as my 'plate' says i can only go 2" larger (or wider, or...whatever!) than standard wheel size which was 15"
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by JShaw View Post
    pics of said "plate"?
  15. #15
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    The reason being no two States are the same with their modification regulations. The OP is a NSW resident (poor bastard, just like me) and this state has probably the harshest registration regulations in the country. It's pointless asking a forum like this for advice because members are regulated differently and most don't know their own state's regulations, let alone another states.
    OP - I don't know the answer, but I suspect the wheels would not be legal in NSW. Your best bet is to check with your local registry or look up the regs on the net.
  16. #16
    vy2 clubsport
    Feb 2008
    adelaide
    i know in sa its 25mm overall rolling diamiter.
    unsure on vic etc sorry couldnt help much lol
  17. #17
    VR SS
    Sep 2010
    May be helpfull
    Tire size calculator
    tyre and wheel calculator
  1. [QLD] Vl commodore, lsd, lowered, p plate legal!
    By eurekamad94 in forum Vehicles For Sale
    Last Post: 02-08-2010, 12:23 PM
  2. Replies: 47
    Last Post: 15-06-2010, 10:19 AM
  3. is this legal?
    By alokin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2008, 05:09 PM
  4. 19" Legal for VT Commodore?
    By cds in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2008, 10:31 AM
  5. turbo commodore - how to keep it legal?
    By tysons_2001 in forum General
    Last Post: 07-12-2006, 10:16 PM
