Results 1 to 4 of 4
Thread: Nolathane replacement parts.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default Nolathane replacement parts.
    So I've had a creaking in my steering for about 3 months now, and I've finally worked it out to be the lower control arm bushes, but whilst i was looking around I found this kit on the Nolathane website. I'm just wondering how tricky it would be to do this stuff myself - keeping in mind I've replaced sway bar bushes and the diff mount bush, so I'm not a complete noob.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the link is asking for year of make and model.. i got mine from repco relativily cheap
    i did mine (VS) the only i could do at home was the bush on the radius rod bush, but the top bush (inner mount) needs to be pressed out. i thought i was clever and was drilling out some rubber then G-clamped the centre out, after a few hours of "fun" i read up and found out they have a metal sleave on the outside. i removed the control arm and took them in to get pressed out. then took em home replaced the bushes bit of grease and happy days
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    inner lower arm bushes most places will replace with rubber not nolathane as its stiff as hell when you do the lowers with nolathane and makes for a not very nice ride
    ve sv6
    Aug 2010
    they dont need to be pressed out, if your handy with a hammer you can whack them out, both the lower inner and the radius rod in arm bush, fitting nolathane is pretty easy as there bushes are normaly a 2 piece bush and you just push 1 1/2 in one side and the other 1/2 in the other side. the main thing to take into account when fitting polyurethane bushes is to make sure there is no rust, dirt or old rubber left in the hole as this will cuase squeeking and premature wear. personaly i would recomend superpro over nolathane, just my 2 cents.
  1. Standard or Nolathane?
    By 9C1pack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2010, 11:03 AM
  2. Replies: 2
    Last Post: 02-06-2010, 04:50 PM
  3. VT SS LS1 recent purchase, 240,000kms, parts replacement
    By VT_Cruiser in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2010, 10:15 PM
  4. ECU/BCM replacement, and remote key replacement/ignition replacement
    By skunks.monks in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:08 PM
  5. Replacement Parts
    By pdxn in forum General
    Last Post: 30-03-2006, 05:10 PM
