Does anyone know if its possible to fit 16 x 7 VT rims to a VX Acclaim..
they should, i cant see why not. my vx s pac came with 16's so they should fit an acclaim
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
Yes, it is very possible
50LTRv8
Thats very interesting cause a guy who sells them brand new on ebay told me the rim would need to be modified for them to fit but who wants to go modifying rims.
The only original Holden rims that you need to modify to fit, are when you're going from VE to VB-VZ because the hub is a different size and needs to be machined out.
Originally Posted by Reaper:
Originally Posted by Jecs:
Once again thats interesting cause I recently had a flat tyre and I had to call RACQ to remove the standard Commodore rim since it was so tight where it fitted over the hub so it must have latter rims fitted.
I returned home and took off the other 3 rims and they all had the same problem so I put some grease on the hub hoping to improve the rim removal next time.
I want the 16'' rims painted flame red and fitted with whitewalls and baby moon caps so will I need the centres machined in a lathe or could I use a small grinding wheel on an air grinder.
Commodore rims tend to rust onto the hub, they all do it.
