Results 1 to 6 of 6
Thread: Wiring a Trailer lights (help needed)
    VS Executive S2/ VT SS
    Oct 2008
    S/E Suburbs
    Question Wiring a Trailer lights (help needed)
    Hi guys,
    A mate just bought a set of lights for his trailer which came with a wiring kit but none of the wires are connected, just wondering if anyone has some hints/tips or knows how to wire it up? It's got a 7 pin connector at the end but not sure which colours go where, or if i need to strip back the plastic to slot the wires in etc and to where so any help would be appreciated. Just wiring this onto a 6 by 4 trailer if that helps too.
    Thanks in advance.
    J
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Oct 2008
    S/E Suburbs
    Thanks for that mate, helped a heap when sorting out the colours etc, the wiring kit only came with a 9m cable, do i cut a piece off to run from the right hand light to connect to the left light which goes back to the 7pin connector? Sorry but i'm quite new to this and would rather try this myself than pay $200+ for someone else to do it, really appreciate your help
    VE SV6
    Jan 2011
    Maitland
    Yes you`ll have to join them some how. Just make sure you leave enought lead at front to allow for turning etc before you cut it or got to auto elec and buy x amount of cable. You`ll also find that the 7pin flat plug when you unscrew it is labelled inside as to what wire screws into which spot.
    I always strip back about double the lenght needed ,twist in a spiral direction then double over on its self ,place this into the little slot and screw down for your connection. Just gives a bit more wire for the join to bite into so gets a better connection. Soldier and heat shrink all joins too
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    a consideration for your wiring;
    I buy a second cable run for the trailer and run one down each side. Mostly because I water-proof them for marine use and don't like splices/joins along the line. Also means if there is a fault you only look at the plug or light housing for faults. Also reduces chance of losses through weak / poor connections...
    my 2c
    Oct 2008
    S/E Suburbs
    Wired up the trailer last night and worked a charm. Thanks for all the input guys, definately helped!
    J
  1. low beam, dash illumination lights and turn signal wiring diagram needed for a vr
    By tt turbo vh in forum Electrical Wiring / Questions
    Last Post: 29-03-2010, 09:16 PM
  2. Head lights wiring help needed...!!!
    By frontier in forum General Discussion
    Last Post: 25-06-2009, 09:36 AM
  3. Trailer Wiring
    By rift in forum Electrical Wiring / Questions
    Last Post: 09-11-2008, 12:53 PM
  4. wiring diagram for rear lights to wire in trailer
    By DJ_TAS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2007, 01:48 PM
  5. Trailer lights wiring loom
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2006, 03:56 PM
