Results 1 to 3 of 3
Thread: Lowering and exhaust.
    commodore VT executive
    Feb 2011
    Launceston
    Default Lowering and exhaust.
    Im new with this site, just wanted to ask a few questions...
    I have bought springs too lower my commodore, can i install them without doing anything else.?
    and should i put an exhaust on for bit more sound or a tip? and will it affect my engine??
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    My understanding is.. If you want to lower a car... you have to get a wheel balance/alignment after
    Exhaust should help your engine... having a exhaust tip wont do anything apart from look good..
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    yes you can put the springs in without doing anything else but if the shocks and struts are original then they may need replacing (just lowered mine last week and the car had done 191,000km on the original spring and needed replacing badly which i did)
    as for the exhaust all it will do is give it a tiny bit more power and make it louder and if your car is a auto then i would recommend a tip because it will reduce the drone that a larger exhaust causes
    Quote Originally Posted by SHEENY05 View Post
    I have always thought a quick six will turn more heads cause if you gear a V8 you sorta expect it to go hard
  1. lowering front without lowering rear.
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2011, 09:46 PM
  2. [NSW] Exhaust System + Lowering or Audio System
    By Gus in forum General
    Last Post: 21-01-2011, 07:55 AM
  3. Exhaust/Lowering.
    By boddyy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2009, 01:32 PM
  4. VT question.lowering & exhaust
    By GenOktOniA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 02:38 PM
  5. lowering and exhaust
    By bennzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-08-2006, 07:41 PM
