Results 1 to 14 of 14
Thread: Where do you buy ignition leads from...?
    VS ute, YZF-R6
    Sep 2005
    Default Where do you buy ignition leads from...?
    This may sound like a stupid question but hear me out..
    I always sourced genuine leads for vehicles in the past when it was cost efficient. Most often it was cheaper to get a full set from Repco for the same price of a single genuine lead.
    Bursons is now in qld and dont stock eagle or top gun brands and only do standard sizes.
    If you wanted to source say 9 or 10mm leads from an ignition supplier even at trade they're often costly for an extra 1 or 2 mm in diameter.
    Ebay is full of overpriced options or at least the same as retail.
    So hence my question where have you found is the best place to buy non genuine larger diameter or standard ignition leads?
    Thanks for the input.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    well, eagle spares are the best for overpriced stock in vic, but honestly, do you need them? whats wrong with stock bosch?
    Jonno's Avatar
    Jonno is offline :)
    Vk
    Nov 2010
    Vic,
    Bosch top gun leads are cheap from supercheap auto man
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VS ute, YZF-R6
    Sep 2005
    Hey no I dont really need them that's right but when people want them, I always find them expensive for what they are from most suppliers.
    I did used to buy them before because they were the only wider diameter I could find. Every little bit helps. Especially if you had points.. ugh.
    Now I think it's cheper to get them made up at the end of the day.
    VP Executive 5L
    Mar 2011
    ICE Ignition for sure.
    I had a set on the car for 12 years till I sold it. They were still just fine.
    Welcome to ICE Ignitions
    VP Executive 5L
    Mar 2011
    VS ute, YZF-R6
    Sep 2005
    I believe you. I remember when this company had started out. Im not doubting their products im sure they're fine for race applications, thats why they cost the earth.
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    VS ute, YZF-R6
    Sep 2005
    Quote Originally Posted by V8VKJoe View Post
    Thanks mate
    ari666's Avatar
    1966 impala
    Mar 2009
    the only think is that these 8.5mm and 9mm leads is they often have crappy internal windings. so even though they are fatter, they cant carry as much current. which i suppose doesnt matter on a stock igntion system
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    Im pretty sure the only difference is the insulation not wire inside the different thickness is just for how harsh the engine environment is (heat ect)
    ari666's Avatar
    1966 impala
    Mar 2009
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    I'll be buying my next set of leads from http://www.jegs.com/ as they seem to be pretty cheap on there. Not sure how much delivery would cost, but if you get a few things you need/want it could make it worthwhile?
    May 2010
    Rockhampton QLD
    Quote Originally Posted by ari666 View Post
    lol ^^^
    im pretty sure bosch make leads with better internal windings that procomp...
    No dout your right bout that there would be slight difference between brands its just the difference between say 8mm and 10mm is just insulation
  1. [LS1] Ignition leads.
    By soop in forum LSx Development and Modification
    Last Post: 29-10-2010, 09:51 AM
  2. What IGNITION LEADS Leads do you use?????????
    By 11gothevt11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2010, 09:03 PM
  3. ignition leads for 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2009, 09:29 PM
  4. Ignition Leads
    By Dougeh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2009, 11:20 PM
  5. Ignition Leads
    By AWETZM in forum General
    Last Post: 05-09-2007, 01:16 PM
Tags for this Thread
