Results 1 to 5 of 5
Thread: V8 not advancing
    vs calais
    Mar 2010
    Default V8 not advancing
    Mucking around with a 304 from a VN commodore thats fitted in a hilux, bit of a rough conversion as in wiring is messy but did run fine apparently. I have done the rear main seal and small tidy up.
    Went to set the timing which is easy enough, will set to base timing but wont advance at all the timing just stays where i set it. this then causes pinging and back firing and lack of power obviously.
    I have replaced the Ignition module with a recon one, still the same, I have noticed it gets hot burnt my hand a little bit, also checked that its grounded and ran a seprate ground to it aswell and still No good.
    I was under the impression that the moudule is responsible for advance and not the ECU
    Any ideas??
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the ecu makes it advance .set base timing to 10 degrees with diagnostic connector bridged so it locks timing at 10 degrees then remove bridge wire and timing will increase with revs
    vs calais
    Mar 2010
    due to the retro fit there is no doagnostic connector that I can see. The bridge will have nothing to do with advancing the timing it should advance regardless.
    If the ecu is responsible for timing then i would imagine it must be a fault with that?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the diagnostic link connector (ALDL) is withen 200-300mm of the ecu plugs should still be on the harness find that and wire in a check engine light and check for codes could be one broken wire to the ignition module will stop all advance if it is.without a check engine light its hard to find whats broken.if the aldl plug is there a tempory check engine light can be wired into it to flash error codes
    vs calais
    Mar 2010
    can someone tell me how to get into diagnostic mode, I have found the plug but do not know what to bridge can some one please tell me what coloured cables need to be bridged.
  1. Cam advancing/dialling
    By stocky in forum General Discussion
    Last Post: 17-10-2009, 06:39 PM
  2. advancing the timing on my vp v8
    By jesse james vp calais 5.0 in forum V8 Development and Modification
    Last Post: 11-06-2009, 05:02 PM
  3. Advancing the cam gears
    By nvs_sle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-10-2006, 05:27 PM
  4. Advancing the timing
    By gibbonsVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2006, 03:22 PM
  5. Advancing the timing
    By ryan_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-05-2006, 08:44 PM
