Hi everyone I need a reply ASAP as to whether the VZ senator brakes will fit onto a VT V6.
Thanks
Glenn
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
Anyone? They're the 330mm front and 315mm back calipers and rotors, will I need anything else to help them fit? or will they not fit??
They will fit if your swapping over rotors and calipers.
I'm fairly confident they will be a straight swap, at worst it may involve an extra bracket but you have guys putting HSV brakes on non-HSV all the time.
The kits are jsut bigger rotors and calipers.
Good luck!
Yes, straight swap, as long as the rotors and calipers are changed.
Cheers fellas thanks heaps.
Yep, as said above, straight swap. Make sure you get the lines aswell as with the 'HSV Performance' brake package, it is a little different.
