Results 1 to 6 of 6
Thread: are all Holden 5lt V8 engine mounts the same?
    VL Berlina S2
    Jun 2006
    Default are all Holden 5lt V8 engine mounts the same?
    Just wondering if anyone knows if there is any difference between HQ-WB V8 engine mounts verses the VN-VS engine mounts?
    bout time for the VP injected 5lt to find its way into the HX's engine bay & I wanted to check if the VP mounts will bolt in there or if I need the earlier mounts?
    retro tech HX project on the go....
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    not 100% sure on this but i think they're different
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    hey mate i just done my injected 5ltr engine moutns . they are the exact same from vn - vs efi 5ltr i know that... pre efi 253/308/ carby models etc the mounting brackets are slightly different but rubber stoppers are the same.. hope that helps
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Different. You need the HQ-WB mounts (as said above the rubber mount is the same, but the metal plate that bolts to the motor is different). The sump also needs to be HQ-WB, just incase you didn't know.
    WL Caprice & VQ Stato
    Feb 2011
    Seaford
    spot on, and oil pick up aswell from memory...
    Jun 2005
    Yeh, the pick up needs to be changed aswell.
  1. VT Engine Mounts
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2011, 05:45 PM
  2. vt engine mounts
    By vtanthony in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2010, 08:21 AM
  3. holden vs engine mounts
    By lyndon_breeze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2009, 09:53 PM
  4. engine mounts in a v8 vs
    By 97 SEN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2006, 08:16 AM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
