Results 1 to 6 of 6
Thread: VZ Senator Manual Conversion HELP!!!
    VZ Senator
    Dec 2008
    Exclamation VZ Senator Manual Conversion HELP!!!
    I recently forked out the cash to rebuild my engine due to a dodgy Adelaide HSV/FPV performance workshop, whom charge through the roof with their television advertising etc. Anyway I'm now making around 310rwkw and 670nm of torque and my Automatic transmission is dying.
    I'm seriously thinking about converting to a manual rather than getting a beefier auto transmission like a Turbo 350 or 400. I previously had a VY Clubsport with a 6 speed manual and loved it! So I'm keen to go the whole length and convert to a 6 speed manual.
    I need to figure out if the T56 TREMEC gear box will handle the torque output and what parts i need and instructions to perform the conversion. I was also looking at the 6060 TREMEC 6 speed manual which comes on the W427 and the new Corvettes, but is a little out of my price range even for a reconditioned one. (I can pick up a brand new T56 for $2000, where a reconditioned 6060 will set me back atleast $3000)
    Any help?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    T56 will hold up to a fair bit of power, plenty of people running big cam/head combo's/superchargers/twin turbo's through the t56
    What exactly was done in the rebuild?
    VZ Senator
    Dec 2008
    I've searched other threads and people seem to put a fair bit of power through the T56.
    I had the heads CNC ported, forged flat top pistons, a 600 lift cam, roller rockers, ported exhaust, block was blueprinted and balanced.
    Also have a 3000 stall converter.
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    VZ Senator
    Dec 2008
    What parts are needed for the manual conversion of a VZ 6.0L?
    Are there any threads that outline the steps?
    Vy Sv8
    Jun 2009
    prob need new loom new computer pedal box gear box slave cylinder oil resevoir clutch spigot bearing thrust bearing clutch pedal and linkages oil lines to run to the slave cylinder and theres plenty i think i left out
    being a vz senator u might need to get your computer reflashed as a manual computer from another car might not support some of the accesorys ure car has. i may be wrongbut
  1. vx senator manual
    By kaneo11 in forum VT - VX - VU - WH - V2
    Last Post: 29-04-2011, 06:56 PM
  2. [QLD] Ve Hsv Senator Rear End Conversion
    By Unit_01 in forum Parts And Other Items For Sale
    Last Post: 16-01-2011, 09:57 PM
  3. 2001 Calais with HSV VZ Senator front end conversion...
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-08-2010, 11:28 PM
  4. Manual conversion for VZ senator
    By CHARGEDVT in forum General Discussion
    Last Post: 14-06-2010, 01:46 PM
Tags for this Thread
