Results 1 to 9 of 9
Thread: Can anyone name this rear brake part?
    1983 VH Commodore SL/E
    Jun 2009
    Default Can anyone name this rear brake part?
    It's the valve that connects the brake line to the two rear calipers and bolts on to the diff. I'm in the process of sorting out the rear end and want to get a new a new part or reconditioned the original
    Daniel
    VH SL/E Blue on Silver
    304 Conversion | Custom Headers | Trans-Go Shift Kit | 2800rpm stall | VL Turbo Diff | VL Turbo rear brakes | VT Twin Piston Front Calipers | VT Brake Booster | Slotted Discs F&R | Nolathane bushes.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    t-piece and/or bracket.... it's just a bit of metal with some holes in it, there's nothing to rebuild just clean it up and be done with it.
    Jun 2009
    Is it just a T piece? I thought it was a proportioning valve (that's what a make said) but when I tried to research it I couldn't find any info on the part.
    I did read some where that with all post 1979 commodores, the proportioning valve was incorporated into the Master Cylinder.
    Daniel
    VT
    Apr 2005
    QLD
    Quote Originally Posted by SLE-883 View Post
    My VG had a proportioning valve. You'll probably find that all the live axle commodore utes had them.
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    I just assumed it was a t-piece and the valve was built into the master cyl - the pic looks to be a sedan, but I know tonners/utes etc in general use a variable proportioning valve with a connection to the tray that adjusts brake bias based on load in the back.
    I guess whether it's a "proportioning valve" or a "t piece" is only determined by the diamater of the inlet hole or obstructions? which still shouldn't need reconditioning/replacing due to presumably nil moving parts etc?
    You could probably measure the hole dia. on a drum brake and a disc brake commo to determine whether or not it's a proportioning valve? or eyeball for a pin/restriction? - I have one floating around the shed I'll check out when I get a moment
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    Okay upon further reading, it looks like commodores do run an in-built proportioning valve in the master cylinder.
    The "cracking pressure" of this is stamped onto the master cyl somewhere in the format "C###" where the #'s are the cracking pressure in PSI.
    From a quick read there's various pressures available - for old holdens, anyway - they were c225, c350 and c450 for drum/ute/disc. Allegedly commodore Utes use a C000, which would make sense - so 0psi cracking pressure, and the proportioning valve in the rear takes care of the bias? And sedans/wagons with drum/disc would presumably get the appropriate valving in the master cyl, and just T piece at the rear? ... interesting though for people doing VT front brake upgrades and retaining standard rears..
    Here's some resources.
    Identifying this master cylinder - GMH-Torana
    Prop Valve - GMH-Torana
    Brake Proportioning Valve - Holdenpaedia
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    It's just the end of the flexible brake hose, it just directs the fluid to each caliper. If you buy a new flexible hose, it will come with the metal end already attached, screw in the metal lines and you're done. If there is nothing wrong with the flexible hose, then don't worry about it. Nothing to rebuild there as VN_Luke said.
    Only utes have a proportioning valve at the rear, which is governed by the load/weight in the tray.
    Jun 2009
    Thanks everyone
    I'm replacing all the brake hoses with new ones so I might as well replace this hose and t piece/
    Daniel
  1. alright so, brake pedal = parkers on front and rear brake light. head lights on and..
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2011, 08:29 PM
  2. Brake Light Switch Part #
    By adz_1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2010, 08:24 PM
  3. rear taillight fixture ,part number...
    By Lukey75 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2008, 02:07 AM
  4. Part number for VE SS rear calipers
    By lumina dubai in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-10-2008, 12:28 AM
  5. vp rear ultima shocks part number?
    By slingshot76 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2008, 03:45 PM
