Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By HoZy
Thread: What sort of hub is this ?? Need help
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    Default What sort of hub is this ?? Need help
    Hey as this title has in wondering what sort of hub this is on the trailer I have, its going to be a motorbike trailer and I would like to put a nice set of rims on it thanks for the help
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    a Wheel hub.
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Feb 2010
    Tamworth NSW
    VY SS
    May 2011
    Auckland
    There are 4 studs so it's 4 by something.
    Measure diagonally across between the centre of the studs. (in mm)
    Common ones are:
    4x100
    4x108
    4x110
    4x114.3
    Feb 2010
    Tamworth NSW
    Feb 2010
    Tamworth NSW
    Also curious while I'm on the subject of the trailer, the trailer used to be a small pop-top caravan, hadn't been register
    In forever, I just took the caravan off cause it was rooted, put a floor down and set it up to hold 3 bikes, I'm just curious about what I have to do to get it road worthy
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    In my opinion i'd chuck the wheels and hubs and fit a set of vn commodore hubs and bearings. This way you can run commodore stud pattern and since you're driving a commodore you've got a spare in the car on hand if need be (assuming there won't also be one on the trailer itself).
    It'll have to go to a trailer place for a blueslip and will get a new number punched into it.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Feb 2010
    Tamworth NSW
    Yea was thinking about throwing a set of commodore hubs on it but couldn't be bothered lol haha
    Ok true true that works for me
    Feb 2010
    Tamworth NSW
    Aug 2008
    NSW South Coast
    Just go to a wrecker and ask for a pair where the discs are buggered/worn out. They 'should' give them to you.
    PM Me For Details
    VY SS
    May 2011
    Auckland
    Why not measure them and start from there. You can do it with a ruler if that's all you have. Easy as pie
    Feb 2010
    Tamworth NSW
    Jonno's Avatar
    Jonno is offline :)
    Vk
    Nov 2010
    Vic,
    its not comm or ford cos their 5 studs
    just get some multi stud rims
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Feb 2010
    Tamworth NSW
    Mmmm true true
    Trying to figure a way of putting commodore hubs on without having the brakes on .... Scratching my head
  15. #15
    Aug 2008
    NSW South Coast
    Why would the brakes be on by using an early commodore hub??? All you would be doing is mounting the commodore hub and bearing onto your axle. You're not fitting calipers or handbrake shoes etc.
    PM Me For Details
  16. #16
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The early Commodore has the hub as part of the rotor. You can get Commodore pattern trailer hubs, but you will need to measure the axle where the inner and outer bearings sit so you can make sure the bearings for the Commodore pattern hubs will fit.
    To get the correct PCD, you need to measure centre to centre diagonally.
    Visit my Facebook page
  17. #17
    Feb 2010
    Tamworth NSW
    Thanks not an abba fan I was sure that was the case with the early model commodore hubs
    I had a look on eBay and saw a few hubs and I'm pretty sure I can make them work but I'm curious, may be a stupid question but what does PCD stand for ?
  18. #18
    VY SS
    May 2011
    Auckland
    Stands for pitch circle diameter.
    If you draw a circle with the diameter specified (eg 102) then drill a number of holes evenly spaced around it (eg 4) then you have a 4x102 pcd
    Makes measuring the pcd on a 5 stud hub much more difficult.
    Not sure where you'd buy trailer 5x120 (commodore) hubs from. Pretty sure Trojan ones are 4x100 and 5x114
  19. #19
    Feb 2010
    Tamworth NSW
    Thanky Milky that helped heaps
  1. The Sort of BT1 VR V6
    By wraith in forum VR - VS
    Last Post: 17-12-2010, 04:26 PM
  2. What sort of Amp?
    By SUSS8 in forum Car Audio
    Last Post: 20-02-2010, 10:35 PM
  3. what sort to buy???
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2010, 07:54 PM
  4. What Sort of Dog is this?
    By Jesterarts in forum The Pub
    Last Post: 15-06-2008, 02:07 PM
  5. what sort of value?
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 02:08 PM
