Results 1 to 8 of 8
Thread: New VL
    vr
    Aug 2007
    Default New VL
    I just got a new vl today and the power windows arent working accept for the front passenger side, other wise the car goes great has anyone got any ideas before I have a look tommroe thanx Pete
    WL Caprice
    Mar 2011
    Try the window switch - possibly a loose common or three broken switches. Do they work from the door switches or not at all?
    VS commodore wagon V6
    Aug 2011
    Windsor 2765
    Quote Originally Posted by CapriciousWL View Post
    I agree, the power window switches are extremely senstive, ever a little bit of cigarette ash could make the switch malfunction
    vr
    Aug 2007
    It has 4 switchs in the cosole and the pas front works fine, the driver side makes a small noise when trying to put up and the back do nothin, What do you mean door switches thanx
    Aug 2011
    Windsor 2765
    The switches on each door that winds them down, like each door has it's own switch on the door itself that you control the window with
    vr
    Aug 2007
    Aug 2011
    Windsor 2765
    Try using a different main switch in the console, just some ideas
    first thing i'd do is change the window fuse and look for obvious loose connections
    otherwise it might be a trip to the auto electricians for you
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    try giving the bottom of the door cards a slight jab or 2 - while pressing the switch
    this used to work on my VN
