Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By wamboin23
Thread: 18 gauge wire through firewall
    Vp
    Jul 2011
    Briabane
    Default 18 gauge wire through firewall
    Just a question on how the @&$&&@&$ you get wire through the firewall?!!!!! I got a 1993 VP Executiveand putting in some gauges and want to do the wiring as tidy as possible.
    I tried going through where the main wiring loom goes through but it's tough as he'll to get into!
    Any suggestions where to go through? Easiest possibly?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by wamboin23 View Post
    clutch pedal grommet.
    just to the right of the brake booster.
    Thats if it is an auto..
    Since mine is a manual, I ran it just next to the main loom on the right side, It was very risky drilling next to it (I was running 4ga), but looks next to factory when its all taped up
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Vp
    Jul 2011
    Briabane
    Surely theres a factory tacho wire already to go but not connected ??
    I'll try the grommet if not
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by Ranuip View Post
    I think he means like oil pressure and what not, if it is tacho, just wire off the cluster
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    erm... is there anough room to guarantee the wire wont foul with the clutch? personally i would avoid moving parts at all costs.
    OP there should be two huge wiring looms. one on either side. just put a tiny slice in the body of the grommet with a rozor blade then stick your wire into it. its easy.
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by ari666 View Post
    says nothing about been manual. if it is there is no grommet there at all. but otherwise there is plenty of clearance if done correctly.
    and yes, there should already be a tacho wire inside the vehicle. you will be able to pick it up anywhere from where the harness comes through the firewall, all the way up to the instrument cluster - brown w/ red trace.
    Vp
    Jul 2011
    Briabane
    Vp
    Jul 2011
    Briabane
    Used the brown with red trace (factory) just under the instrument cluster. Heaps easier than going through the fire wall! Thanks bro
    Vp
    Jul 2011
    Briabane
    Got another one for ya, which wire is the water temp inside the car?
    And if there is one, is there a oil pressure one or do I need to install the sender unit before installing te oil pressure gauge? Cheers
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    its dark green, but you need to run a seperate sender unit for each gauge. you can't just splice into it and use both the dash gauge and the aftermarket gauge. its one or the other.
    no oil pressure, just the wire for the idiot light. so install the oil pressure sender, then run a new wire, and go to the gauge.
    Vp
    Jul 2011
    Briabane
    Ok. Cheers
  1. amp power wire through firewall - manual vn
    By VNexecutive in forum Car Audio
    Last Post: 13-11-2010, 12:11 PM
  2. more on this bloody gauge install, weres a good hole in the firewall?
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 01:52 PM
  3. Running a wire through the firewall
    By KnobMuffin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2009, 07:26 AM
  4. 4 Gauge power through VS firewall
    By cwyndham in forum Electrical Wiring / Questions
    Last Post: 30-12-2005, 01:10 PM
  5. Replies: 9
    Last Post: 22-07-2005, 09:40 AM
