a mate of mine is building an old dodge pick-up that will be running a mild carbureted small block chev, he has found a good 4L60E out of either a vr or vs and what we need to know is..
is there any way this box can be made to work without a computer? i'm well aware that the 4L60E is electronically controlled and that the vn-vp T700 would be the prefered option, but im wondering wether say fitting a full manual shift kit, or even an earlier non electronic valve body out of a T700 would make the 4L60E work ok on its own?
I'm not 100% sure, but I would assume it would need the computer to power all the solenoids and stuff.
Ronald Reagan (1986)
You can have it built so it is a full manual shifted auto and flick the lock up torque converter and then there is no need for any computer for the box.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
i am looking at doing this to the 454 going into the impala. so far i have read that:
the 700-r4 has a different bolt pattern on the nose, so you cant take a speedo cable nose and fit it to the 4l60e. BUT there is a mob in the states modifying the noses to fit the 700r4 speedo cable. apparently there is a gear on the output shaft to mate with the speedo gear: GM 700R4 4L60E TAIL HOUSING NO MOUNT HOLES LARGE SPEEDO | eBay but i still have my doubts about it. because the more pics i look at of the 4l60e's output shaft, there is no accomodation for a gear and the more i look at the snouts, there are 4 holes for the 700 and 6 holes for the 4l60e
so really the only option i have found is at castlemain rod shop: (SCXBOX - CABLE X ELECTRONIC ADAPTOR - $895.00)
Speedo cables and accessories![]()
which take the speed pulse signal from the gearbox and converts it to mechanical (speedo cable) drive.
the more i read into the manual switch for the torque lockup, the less i like the idea. you will need to constantly remember to turn it off, because supposedly the clutches for it are UBER weak, and having it locked while moving off from a stationary position (from what people are saying) pretty much destroys them.
all of what i know has been read in the past 4 days thanks to google. so i am really keen to hear input on this swap too. i would rather have a 4l60e or a 4l65e (or 4l80e but im not a millionaire) in the impala than a 700r4.
edit* bah! re-read original post. you wanna know the oppositesoz. im not deleting that post
why not just use a 700r4 with cable kickdown? its already set to work with no ecu afaik.
