Results 1 to 5 of 5
Thread: T5 V6 box into V8
    vs s pack (hsv conversion)
    Oct 2011
    Northampton
    Default T5 V6 box into V8
    both gearbox's are equal strengh just differant ratio's so the inpuut shaft wont fit the v6 box so it's of to the engineer's to have it modified everything else is the same..
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Not sure if there's a question in there? But other than ratio differences as you've outlined, the main difference is that the V6box input shaft has to be shortened approx 50mm to suit a V8 application. Also have different clutch cable, bellhousing and clutchfork. A V6 clutchfork however can be modified to suit a V8 by removing the large weight block on it.
    Clutch assembly is obviously also different.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by vshsv View Post
    And????
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Morton's Avatar
    Fairstar the Funship
    May 2006
    V8 T5 gear clusters are larger, and stronger.
    The 1972 HQ Kingswood
