Results 1 to 15 of 15
Thread: ticking noise when i accelerate
    1995 vs commodore
    Oct 2011
    bribie island
    Default ticking noise when i accelerate
    i have this really annoying ticking noise coming from somewhere in the front of my car only does it when i take off/accelerate. only started doing it after i got pacemaker extractors high flow cat and exhaust on it echoes really bad when i drive past something. sounds like a chuckling/ticking noise.. any ideas please?
    VE SSV 60th Ann
    Oct 2010
    VR Calais
    Mar 2011
    Plumpton
    Crack in manifold maybe
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    1995 vs commodore
    Oct 2011
    bribie island
    Quote Originally Posted by bonners View Post
    Got a cam upgrade?
    nope just has the exhaust
    1995 vs commodore
    Oct 2011
    bribie island
    SilverVH is offline Banned
    Nov 2005
    Exhaust leak.
    If it's more audible on the gas rather than off the gas, then 100% it is. Just find where the black carbon build up is on the joins of your pipe and there lies your problem.
    1995 vs commodore
    Oct 2011
    bribie island
    Nov 2005
    When an engine is under load and creates backpressure in the exhaust, the pressure buildup will find any and every possible escape outlet. The ticking noise is the pulsating of the exhaust cycle in unison with the engine. As RPM increases, so will the occurence of the audible noise. If you accelerate heavily followed by closing the throttle, more than likely the noise will reduce or disappear. This is the sign of an exhaust leak.
    To rectify you can either:
    1. Visually inspect the exhaust system for signs of leakage and rectify with either the applicable gasket or sealant and/or by correctly torquing the bolts to their specific requirement.
    2. With the car running, pinpoint the source of exhaust leakage by putting your hand close to each join in your exhaust system from header back and feeling for any escaping exhaust gas. Listening to where the noise is most noticable will aid in resolving the source.
    My best guess going off your description would be to check the mating surface between the header and the head.
    Hope this helps.
    1995 vs commodore
    Oct 2011
    bribie island
    Quote Originally Posted by SilverVH View Post
    Hope this helps.
    cheers for that man hope i can get it sorted
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah like mentioned above, its an exhaust leak. Get under the car at night with a torch and see if you can hi light any exhaust smoke.
    A torch should bring it up pretty easy, otherwise run your hand near where you think it may be and see if you can feel exhaust pressure blowing against your hand...
    Almost 100% sure its a leak based on the extractor change...
    Mine did this after blowing out the gasket between the end of the extractors and the front of the exhaust section, then a couple of weeks later it did the same thing to the gasket where the cat bolts up.
    1995 vs commodore
    Oct 2011
    bribie island
    Quote Originally Posted by 304runner View Post
    could it be my idler pulley just put a screwdriver on the head of the bolt and end to my ear and it sounds rooted??
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive got a similar ticking type sound coming from the front of my VS, which you can only really hear when driving alongside a wall or road divider etc. Ive also got pacemakers fitted. Ive been all over my cars exhaust system, and Ive also had it back to the exhaust guy who originally fitted the system, and they went all over it and couldnt find any leaks etc , so its got me stuffed what it is.
    1995 vs commodore
    Oct 2011
    bribie island
  15. #15
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by Brett_jjj View Post
    If your tick is only audible when bouncing back off a wall etc it may be just due to your pacemaker header pipes. With large primary pipes on a v6 say, 1 5/8" and larger (and especially when combined with a cam profile more aggressive than stock) it is common to have valve-train noice amplified and echoed in the primaries. This gives a ticking noice. Exhaust wrapping the first 12" of each primary will solve this as it dampens the noise.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
  1. ticking noise
    By mike4226 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-12-2010, 06:23 PM
  2. windy noise when i accelerate & engine our problem
    By Adriianz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 04:46 PM
  3. ticking noise
    By trentvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-09-2009, 05:26 PM
  4. Ticking noise!
    By ucd939 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2008, 05:30 PM
  5. hollow noise when accelerate
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2007, 10:15 PM
