Results 1 to 5 of 5
Thread: L67 Swap in a Hj
    HJ Holden
    Oct 2011
    emerald
    Default L67 Swap in a Hj
    Im currentley converting a L67 and m30 out of a wh 05 statesman into a Hj Holden. Im using pat gardener mounts and CAE wiring harness and computer reprogram, I haven't hit any trouble yet but any heads up on trouble people have had doing this would be great also any recomended mods for these engine. Im planning to intercool a2a it and blow around 15-17 psi with yella terra( am i just being stupid), also all the simple mods from mace such as heat sink plates and throtle body ect, also looking at a larger cam. Any info woukd be appreciated as im new to these engines and still learining
    VS Berlina
    Mar 2011
    Woodford QLD
    I cant comment on the technicalities, but if you're sticking an L67 into a HJ, I sure hope you do a build thread on it.. interesting and different, love it.
    VS Stato l67
    Mar 2009
    Melb
    l67torque.com has heaps of technical info on these engines. What sort of a2a intercooler you thinking of running? MACE or BYE or did you have some other in mind?
    HJ Holden
    Oct 2011
    emerald
    VY SII HBD Calais L67
    Dec 2006
    Will be a nice conversion. The L67 is designed for pulling big heavy barges around so in a light HJ it will haul. XP Hot cam from zzperformance.com or an Intense stage 2 blower cam from Intense-racing.com would be my pick. Water to air is my preference for intercooling as it's as instant as it gets under the throttle. Either MACE or Yella Terra have good options. I may be able to help you with tuning once it's all in as the A2A won't run that great on a stock tune and a cam with either W2A or A2A will be way lean after the mid range and lacking timing
    VYII Calais L67
  1. [NSW] SWAP vy/vz power window main switch swap GREY for BLACK
    By 2Com in forum Swap / Wanted to Buy / Trade
    Last Post: 05-08-2010, 11:44 PM
  2. [VIC] [SWAP - VIC] holden vp calais 5ltr (5000/swap)
    By slepar in forum Vehicles For Sale
    Last Post: 28-12-2009, 11:38 AM
  3. [VIC] WANTED TO SWAP PLUS CASH ADJ: SWAP MY IPHONE FOR A NOKIA n95 + $$$'S
    By Cobez in forum Swap / Wanted to Buy / Trade
    Last Post: 25-03-2009, 12:56 PM
  4. Replies: 2
    Last Post: 27-09-2006, 11:29 PM
Tags for this Thread
