I'm currently upgrading my sound set up in my vt commodore and I was just curious on how your meant to get the head unit radio out seeing as it need the correct pins.
whether their is an easy short cut or something.
but I've been told that by playing around with it you risk deploying your air bags off and stuffing up the ecu codes and stuff like that.
like bend them?
4 holes, so 4 pieces of coat hanger straight down the holes,then wriggle and out she comes
Get a coat hanger, cut it in 4 bits, about the lenth of a can, then when u look at the front of the stero u will see 4 little hole 2 on each side, push the coat hanger in the hole, when there all in, just pull it back slowly and all good shes out.. gd luck.
cheers, i read that one google.
wasn't too sure if that'd work.
but I'll give it ago haha.
while I've posted something instead of posting a new post.
what sort of spring would you recommend running with 18' rims.
like just king springs or ultra lows or something like that.
that's not going to be a massive expensive job?
