Results 1 to 14 of 14
Thread: advantages of a corvette servo?
    2003 vy s-pack
    Nov 2011
    Ballarat
    Default advantages of a corvette servo?
    Hey there. Thinking of putting corvette servos in. What are the advantages? There going in a VY L67. Should I put them in. Yay or nay?
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Pretty sure there is just one servo. They are only like $20 in parts but could be a couple of hundred in labour to get it fitted. It'll probably be a 2nd apply servo, which means shifts involving second are improved. I found especially the kickdown from 3rd to 2nd much faster/firmer.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    1-2 servo and 3-4 servo.
    1-2 is most commonly upgraded.
    A transmission shop will charge you like $300+ for a corvette servo fitted which is a bit of a joke, it's no more than half an hours work and that's being incredibly generous... really only 15 minutes. a tiny bit of fluid (maybe) and $20 for the part, you don't even have to drop the transmission pan to fit a corvette servo .
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    My local joint fitted the servo for $30 when I was getting an oil change.
    Ronald Reagan (1986)
    2003 vy s-pack
    Nov 2011
    Ballarat
    It's just a 1-2. I'm putting it in myself.
    So yay or nay to them?
    How much harder will it shift?
    Will it chirp second?
    EVIL304
    Oct 2011
    Feel free to correct me if i am wrong but arn't VY model trans less mechanical and more so a computerised tune?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by 5LVTSS View Post
    You can change shift points and firm up the change with the computer....but non the less its still mechanical
    OP...the corvette servo obviously does whats been stated because of the larger surface area and also generates less heat thru the clutch packs due to more fluid being able to be moved around which intern will lead to a longer life expectancy of the trans
    EVIL304
    Oct 2011
    Thumbs up
    Quote Originally Posted by Munz View Post
    Fair enough answer only reason i ask is when i had my car shift kitted and had corvette servo's put in. Some shops i rang said they dont do my model of car because it was more of a mechanical shift kit needed for my car and they only specialised in the electronical shift kit tune.But yes i understand its still mechanical thanks for clearing things up for me mate.
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    any trans with the E on the end (e.g 4L60e) can use the electronic shift kits however due to the design of the vehicle ECU, shifts may become softer with increasing rpm due to torque reduction programmed into the ECU
    So in reality modifying your box was best way to go - at least it will shift hard at high rpm
    EVIL304
    Oct 2011
    Thumbs up
    Oh yes it shifts hard in any gear at high rpm but is smooth when being light footed when your driving the grandparents around cheers for all the info mate
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Quote Originally Posted by nathanVS View Post
    I had a place near me but the shift kit in , corvette servo and auto service for $300 back in the day
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    i did the shift kit on mine recently and it was a prick of a thing to do by myself and took me and hour and a half and thats using a hoist and one of the rings thats meant to be loose was jammed when i put it in which caused the trans to slip while driving so i took it to a trans place and $80 and an 40 minutes later it was fixed and it was a small improvement but no chirping
    Quote Originally Posted by SHEENY05 View Post
    I have always thought a quick six will turn more heads cause if you gear a V8 you sorta expect it to go hard
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    A full shift kit is different to just the servo.
    As said above, the servo has a larger surface area for the oil to push against, giving a firmer, quicker shift. When cruising, the oil pressure isn't as high so u get soft shifts, but when booting it, the oil pressure is higher, which will give you a jolt as it kicks into the next gear.
    A full shift kit involves changing internal springs and other bits which I can't remember off the top of my head. The servo doest come the kit, nor does the beast retraction shell.
    Whether it chirps, depends on engine, tyre quality, road surface temps.. A lot of factors.. Chirping shouldn't be ur main concern
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. corvette servo
    By spud_22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2011, 03:40 PM
  2. Billet servo or corvette servo?
    By Hallsy02 in forum General
    Last Post: 27-01-2011, 08:32 PM
  3. [QLD] Corvette Servo
    By Blakvsexec in forum Parts And Other Items For Sale
    Last Post: 17-07-2010, 07:35 PM
  4. corvette servo
    By 94calais in forum General
    Last Post: 18-04-2010, 05:41 PM
  5. Corvette Servo
    By Spaced in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2007, 02:13 PM
