Results 1 to 8 of 8
Thread: vy commodore a/c not blowing cold air
    vy commodore
    Feb 2012
    australia
    Default vy commodore a/c not blowing cold air
    I am having a problem with my VY berlina A/C ,it works on all speeds but no cold air comes out .It has been to holden and they cannot find the problem . They want to change the whole module (not sure what you call it ) the part that you are looking at when you adjust your settings .
    Is there anything else i can check ?Oh and by the way it is climate control
    shaun
    VY S Series 2
    May 2010
    have you tried re-gassing the aircon? dunno if they checked it or whatever but could be the problem
    vy commodore
    Feb 2012
    australia
    Yes that was the first step at the a/c mechanics then they sent me to thenholden dealer from there and still not fixed . They tell me that the computer (something like that ) thinks it is like -20 degrees and it will not allow it to get cold problem is they do not know why , and do not want to order the parts in without knowing What the problem is . .......driving me nuts
    vy commodore
    Feb 2012
    australia
    I have no idea of part names but the part that goes from the engine bay into the car ( block shaped thing) it is cold if that helps
    VY S Series 2
    May 2010
    Is there something wrong with the sensor? to me that sounds like the cheapest part to start replacing
    Although with the computers and stuff i figured holden would be able to identify the problem
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Sounds like the evaporator temp sensor, this tells the computer how cold the evaporator is. If it thinks its -20 then it wont pump refridgerant through it which is why no cold air comes out.
    Sensor on its own should be able to be replaced, no need to replace any modules.
    Quote Originally Posted by moggy
    That was pretty gentle and loving. Assault my arse.
    vy commodore
    Feb 2012
    australia
    Mar 2008
    ^ Im having the same problem in my Calais.....
    Where exactly is the sensor?
  1. Vs commodore blowing fuses
    By Jono v in forum Electrical Wiring / Questions
    Last Post: 26-06-2010, 04:17 PM
  2. vt wont start & blowing cold air
    By Adriianz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2009, 08:11 PM
  3. mazda 626 - blowing white smoke when cold
    By lowrida56 in forum The Pub
    Last Post: 01-05-2007, 10:54 PM
  4. climate control blowing cold aircon on cold days
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 03:24 PM
  5. vr climate control blowing cold when set for hot
    Last Post: 28-11-2006, 06:10 AM
