Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree3Likes
Thread: Tyre pressure 215/60/R16 95V
    Specialized 29er Hardrock Sports Disc
    Dec 2012
    Queensland
    Default Tyre pressure 215/60/R16 95V
    This is something I've never thought about having had only 15'' tyres before, today I had 4 new 16'' tyre fitted and latter I checked the pressure and I find theres 52 things of pressure. Now I'm wondering if the larger the tyre size the more air pressures required.
    VX Clubsport R8 6-Speed
    Feb 2006
    Radelaide
    K-BAGZ's Avatar
    K-BAGZ is offline De Plane! De Plane!
    VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
    Dec 2012
    Far North QLD
    Tyre shops always pump the pressure right up to max unless you specifically tell them what you want.
    First thing I usually do after a tyre fitment is drive to the service station and purge/fill the tyres with the correct pressure.
    Buy one of those magnetic tyre gauges and leave it on your fuel flap or in the glovebox.
    My Pride and Joys
    ---|94 VR S2 S-pac Ute|---
    ---|06 VZ SV6 Sedan|---
    Omnium Gatherum
    http://forums.justcommodores.com.au/signaturepics/sigpic106235_1.gif
    Deuce's Avatar
    Deuce is offline Super Stock
    '94 VR SS V8
    Feb 2012
    Quote Originally Posted by K-BAGZ View Post
    Why would they do that?? They should set your pressures for you.
    34-36psi is a good pressure for a softer ride around town, I pump mine up to 40psi before long trips on the highway though (better fuel economy)
    K-BAGZ's Avatar
    Dec 2012
    Far North QLD
    Quote Originally Posted by Deuce View Post
    Must be one of their procedures. Because every tyre fitting place I've gone to with numerous cars (Tyrepower, Tuff Tyres, Beaurepairs, Bridgestone) have all pumped the replacement to the maximum pressure stated on the tyre, unless you tell them what you want. They don't even tyre shine your sidewalls anymore. Bloody slack if you ask me.
    It could be just Mt Isa tyre fitment places though.
    That's just my experience.
    My Pride and Joys
    Omnium Gatherum
    2013 Ford Ranger
    Mar 2013
    Holden Country
    Thanks guys, I'll go let some air out and yes a softer ride for the outback Qld roads sounds perfect.
    31.05.13 update - Hubby now tells me he travelled 100klms on the tyres at 50 odd thingys and I go let out some air and he's thinking WTF has happened.
    Feb 2006
    Radelaide
    I sell tyres as a job and I nor any of the fitters would ever pump tyres up to Max pressure unless the customer specifically asked for it. That size tyre always 34-36 except if towing or country driving as said above
    VS_Pete's Avatar
    VS_Pete is offline Donating Member
    Dec 2007
    The VS 15s always ran 36psi.
    The VE 18s 36psi
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    Quote Originally Posted by c2105026 View Post
    "when you find a mosquito has landed on your balls, you will realise not all situations require violence"
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VE SV6 MY9.5
    Mar 2012
    Ballarat, VIC
    Maybe related, or maybe not....
    We've returned recently from a trip to Victoria and found when we got back behind one rear wheel lots of tiny bits of rubber all over the back of the car, its only on one side... all tyres are the same type, the rear were at 39psi, front at 36, just wondering, could this be a possible alignment issue with the wheel, faulty tyre, or just paranoia?
    VZ SS THUNDER 6.0l 6 Sp
    Jul 2012
    SOMEWHERE in the land of OZ
    Quote Originally Posted by KustomKulture62 View Post
    This something I've never thought about having had only 15'' tyres before, today I had 4 new 16'' tyre fitted and latter I checked the pressure and I find theres 52 things of pressure. Now I'm wondering if the larger the tyre size the more air pressures required.
    You,ll probably find their regulator is set to 50psi +- 5psi and they just hold their finger on the trigger,that way its (popping )the tyres on the bead,pumping the tyres up,all in one hit.Saves them from thinking & Depending how far up the road you checked them,if they had got up to operating temp,then the pressure will increase a few psi.
    Follow VRSS advice
  1. tyre pressure
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2010, 08:52 AM
  2. tyre pressure
    By sheepz in forum VE Holden Commodore (2006 - 2013)
    Last Post: 26-11-2009, 01:02 PM
  3. tyre pressure
    By Chlippry in forum General
    Last Post: 02-11-2009, 09:26 PM
  4. Tyre Pressure
    By dephilile in forum General
    Last Post: 14-04-2008, 01:07 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
