Results 1 to 12 of 12
Thread: mods for vt 195i
    98' VT Calais s1 - 195i
    Jun 2006
    Default mods for vt 195i
    hi all, please help me out with some info, i just got a vt 195i calais and have no clue on 8's, what are some nice cheap bits can iadd to freshen her up a bit eg. good air filter, injectors, oils... also how much work is involved getting to about 260kw.
    cheers all
    commod8's Avatar
    commod8 is offline swim wit da fishes
    VR Executive V6 Auto
    Apr 2005
    hey heeno. well firstly do you want 260kW at the flywheel, or at the rear wheels? anyway, there are plenty of things you could do, just depends on what budget your on. firstly you could get a cold air intake, a lot of people believe it's ideal to get the cold air intake from a supercharged v6 commodore (i think you can pick one up for about $60 from holden). you could a POD air filter also. some may argue that a POD is a waste, some say they notice a difference. If you were to get a POD, it would be good to have it shielded by the airbox (airbox would need to be modified in order to shield a POD filter). a great thing to do, that may not be "cheap" is to put a set of extractors on, and a nice cat-back exhaust. you could also get a new camshaft and get a custom tune. there's more you can do, and i'm sure the others can guide you a lot better than what i have.
    hope this helps, and good luck
    E Series
    Jun 2006
    cheers man, yea im going for 260 @ the wheels, i've already got the hsv intake on there with a k&n panel filter (only got today ) so inductions alright, getting it lowered this weekend and proper extractors and twin 2.5' go on when the tax man gives me back some money so after that i'll have the basics down pat, then im thinking of getting a cam bigger/better injectors and maybe some nice pistons...then chip n tune.
    thats really all i want to do for now, how much rwkw do you all think this setup could produce.
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by heeno
    cheers all
    try posting in the v8 section,ull get more replys in there and check out some of me threads for power gains in there might help you out for selections
    Cheers.
    * RVN 355 *
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    260rwkw will cost you big $$$$, it takes alot of work to get the 304's into this power bracket.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    260rwkw means you have two options, boost or more cubes. You are going to have to strap a s/c on the side or look at a heavily worked 355 stroker to pull those numbers, or both.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    Jun 2006
    Ok then, 260rwkw might be a bit large, how bout just doing cam, chip, pacy xtractors, injectors, strengthen auto, bigger throttel body and forged pistons
    Morgasshk is offline Morgasshk
    VY Exec 3.8L Sedan 9C1 Pack
    Aug 2005
    Quote Originally Posted by kill -9
    big dittio there. :P
    minux's Avatar
    Feb 2005
    Just buy an LS2 crate motor 6k if you look around, then a nice 6 speed 5k if it is upgraded to handle alot power (both new). Then tune, cam and exhaust it and say hello to about 300rwkw
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    thatll cost you a LOT of money to get fitted and running, LS1 would be mich cheaper
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    dont let these guys dampen your enthusiam, if you wanna work your 304, then do it man...
    dont bother with injectors mate..unless you wack on a blower the ones you have will be more than sufficient. also, if you went as far as replacing pistons you may as well up the compression and port and flow match the heads and manifold, along with new lifters, valve springs and roller rockers.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    a 304 will easly get 260kw at the flywheel
    30thou oversize trw flattops
    sig earson HLM320 cam adv 6deg
    gusset around valve stems
    a desent set of headers
    leave everything else stock (unless you plan to go over 6000RPM)
    timing 38deg @3000RPM
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  1. vt clubsport 195i or vx ss?
    By stormsearcher in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2009, 09:37 PM
  2. Chloe's '98 HSV Enhanced VT SS 195i
    By MzVTSS195i in forum VT - VX - VU - WH - V2
    Last Post: 16-08-2008, 02:29 PM
  3. vk mods`!!
    By Vkcalais8 in forum General
    Last Post: 22-11-2006, 09:23 PM
  4. NEED YOUR HELP RE 195i
    By clubbie_50 in forum V8 Development and Modification
    Last Post: 11-01-2006, 09:32 PM
  5. gas and mods
    By timmyscommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2005, 02:22 PM
