Just got a few questions about gas systems, first one is, what are the different types?
I know on my magna the gas is injected via an adapter at the throttle body, but this seems like a pretty cheap setup. Are there setups that inject the gas through the cars injectors?
How is it done with a straight gas setup.
Now how would a supercharged VT go on straight gas, im not worried about any loss in performance because this will be made up with mods done, but im more worried about how the engine will hold up and could there be any damage done to the charger?
gas can either me mixed in the the and go through with the air or it can be pumped in through the injectors, with straight gas you will gain power as its got higher octane than petrol. also it will work nicely with the blower. check out Gasresearch.
How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
Gasresearch uses a carbie though, are they any systems which are efi?
i'm not very knowledgeable in this field, but from what i've been gathering up theres 2 types of gas injection:
vapour injection and liquid injection. the latter isnt avaliable yet. both however would give you approx the same if not better economy and power as petrol.
i'ld post more info but it'ld be wrong so i wont.
i know i'm waiting for the liquid injection for my car!
try a search this has been covered before... you need injected gas systems with forced induction not mixed gas systems (which cause backfires and blown gaskets)... I know a guy who tried that setup with a blown 351 and had nothing but troubles !
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
It can be problematic, but it can also work very damned well, there's a fella running a turbo 4.1L XE on the BBQ juice and it's running 10's! Apparently quite reliable as well.Originally Posted by sixshooter
Vapour injection systems are available that would probably work well on the super6, check this out: http://www.gas-injection.com/ Saw this dude on the telly a while back, the system looks pretty promising. There's a dyno graph on there of a VY clubbie with the system, it actually gained power all through the rev range!
Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
Luke Duke: You mean you're gonna make sweet love IN it.
Beau Duke: Oh no, I'm gonna have sex with it.
i know of an early anglia hotrod with lpg on a turbo 1gg toyota in it, makes an easy 200 rwkw, had some problems setting it up but its pretty good now
Rob
i'll be able to provide abit more info as it gets done but my cars booked in at the start of November for a conversion. he's going to try and do a gas injection setup for me, but he's unsure if it can be done due to space constraints with the supercharger or something, i'll ask him again when i'm down there friday. he did tell me hes done a fairfew super6 conversions in the past, all of them with the gas mixers. only 1 had a backfire due to faulty plugs....
