Results 1 to 7 of 7
Thread: sagging ceiling trim - how to fix?
    judoman Guest
    Default sagging ceiling trim - how to fix?
    I have a 1996 VS Commodore whose ceiling is all falling down. Someone told me that the basic idea is to:
    1. pull out the plastic ceiling 'corner thingies' that hold up the ceiling, which will then come out completely.
    2. scrape off all the old dead glue (little gold balls of foamy stuff) from the fabric and ceiling
    3. use a can of spray-adhesive on one or both surfaces. stick it back up there, and replace the corner bits.
    Is that an easy job? Or is it a lot more complicated in reality? The repair folk want to charge me $200 ... how long would it take to do it myself? How difficult is it? Any tips?
    thanks!
    VR V6 5-speed
    Jun 2006
    ive got the same problem with my vr i just sprayed some contact adhesive on it then put it back, it only lasted 3 days though
    haynze Guest
    i think you should look around.. i got someone to fix mine with a whole new carpet for only 100 dollars i think it was
    Spike79's Avatar
    Spike79 is offline Just Confused!
    VZ Adventra LX6, VP Berlina LX, Citroen C3
    Bubble Shooter Champion! X-Pipes Champion! Alu`s Revenge Champion!
    Feb 2006
    Brisbane N/W Ferny Hills
    From the How-To section.
    HOW TO replace headlining
    It should clarify things for you.
    Mike's VP Berlina LX... Click Here
    Mike's VZ Adventra LX6... Click Here
    Mike's VP - Most Stock Award - March 07, October 07, April 08
    VK
    Jul 2004
    just buy another one from a wrecker for less than 100, fixing it is more trouble than its worth
    Oct 2006
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Got a near new roof lining for the wagz for $19 from a wreckers, much easier than fiddling around with regluing the old one, scraping all the foam off, etc
  1. Sagging in the A#$e End!
    By Waussie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2007, 01:44 AM
  2. Sagging Doors!
    By bertusmcspurtus in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-09-2006, 03:15 PM
  3. VR/VS ceiling retrimming
    By funkster in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-11-2005, 10:45 PM
  4. Ceiling board
    By vn2nv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2005, 02:39 PM
  5. Ceiling Material
    By arty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2004, 12:20 AM
