Results 1 to 3 of 3
Thread: intake air temp
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Default intake air temp
    heard a rumour about disconnecting the intake air temp sensor in the manifold and it drops the 1/4 mile time pretty signifigantly.
    i dont see the logic in it cos if you have a good tune it would run worse from overfuelling as it see's the engine as being stone cold
    VP Executive R-spec
    Jan 2005
    Mm well if you had enough of a motor to use the extra fuel it might just work with your foot on the floor in a straight line. You will also gain 3 degrees of spark advance since that changes with the temp too but yeah pointless if you have tune
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    Hey .... why not just install a switch for when you want to play ..... then turn it back on for economy .....
  1. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  2. Intake Air Temp
    By Shifty1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-10-2007, 08:15 AM
  3. Air intake temp gauge
    By bundysmurf in forum V6 Development And Modification
    Last Post: 08-04-2007, 08:16 PM
  4. air intake temp gauge
    By bundysmurf in forum Electrical Wiring / Questions
    Last Post: 11-03-2007, 07:20 PM
  5. air intake temp sensor
    By tmaybz in forum Electrical Wiring / Questions
    Last Post: 25-01-2007, 07:52 AM
