ok i have a S2 VP 5spd with a VRs1 motor. this year im spending a fair bit on my car, BUT i dont know the best option.
1. work the motor in it.
2. dump in ecotec
3. dump in alloytech
which wud be the best bang for buck option (i only care about performance)
cheers for any help/advice.
does it have to be a v6?? dropping a v8 in would give you more power and torque straight off the bat with room for improvement.
if it has to be a v6 id (biasedly) say the ecotec, but to put it in a vp would require some work.
yeah you cant go wrong with a 304 but if sixes r up your alley then what about the ecotech super six
I'd go 304 and stroke it, as the other guys stated if you insist on the sixes then ecotec would be my pick also.
hmm im sticking with a 6, i thought about an L67 but i imagine theyd be too expensive and id have to get it engineered. i know the ecotec will fit straight in and i can just use all the wiring from my car. would i get more power from spending 5 grand on the VR motor or the same amount on an ecotec?
you'd have to get an ecotec engineered as well, not anything major...we're lucky we live in qld - for an engine substitution like that you just need a mod plate and most good registered mechanics can issue that.
also an ecotec isnt a straight "drop in" for a vp, there actually is a bit of work involved to make it run...have a look at hozy's thread (v6 section) where he did a ecotec into a vn.
if $5k is your budget then id say to grab a supercharger and wack that on your current engine, vr's have pretty low compression (in comparison to the ecotec) so they can take decent enough boost.
hmm sounds like a better idea, also a blower might be a bit cheaper to do. and less mucking round =) my next rides gonna be a VS s/c calais with a manual box behind it!
Cheapest option for performance...??? How much do you want to spend ???
Probably the cheapest performance upgrade for a VP would be a Stroked 304 to GTS-R or better spec !!! That might sneak you into high 13's to low 14's with a LSD... I wouldn't stuff around with swapping in 6's such as Ecotecs or Alloytecs as it could be more expensive and time consuming with engineering it to keep it legal, etc. How good is your car ? Might be better to upgrade to a v8 equipped car.
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
my car mungs on most V6's it sees with extractors and a stock exhaust... im thinkin id be best off working my motor as the only decent ecotec is the L67...
RB25DET - 500RWHP stock internals,
1JZ-GTE - upto 1000RWHP standard internals...
Both motors around $2500 with looms and ECU, can be picked up at $2000 witha manual box at times too...
no 8's i like my 6'es and dun want any dodge imported japanese stuff![]()
haha dodge i like your style
[= i wanna stick to commo motors, those japanese ones look all... funny to me :|
blow ur beast, then if u do get sick of it and wanna do a conversion later on, u have the charger sitting there to drop on ur next project
if u dun wanna go blow styles, go the ecotec!!
looks like im putten on the raptor blower kit and some engine work weee [=
I'd tell you my selection but since you have picked one i'll keep quite and show you all one day my conversion.. Good choice but
Originally Posted by Yoda
i wish i coulda got an alloytechthat wuda bin great!
Do my trick. Work the VR's internals. You can build a nasty motor cheaper than you'd think.
hell yeh, just found out the buick Ln3 has more power then the ecotecs when force fed, there was actually a FWD turbo motor of this one in america :O
