hey guys was just wondering if anyone could help me out with getting a stroker kit for a 3.8 litre v6 (vp)......i am in melbourne........anyone know of anywhere that can order me a stoker kit and fit ir for me as well?? cheers![]()
anyone? i am after a stroker kit and cam to suit fitted.........anyone know of anywhere?
try www.comeracing.com
I stroked my ecotec from COME, I went all out on the engine because I want to supercharge it later on![]()
Ring or email Sam, he was very helpful with me choosing what kind of stroker that I wanted
208rwkw 13.5 @ 102MPHSTROKED AND BLOWN
wikkid thanks buddy!!
with c.o.m.e. located in melb you could probably even drop off your car for them to do and save on freight costs sending them your engine to re-build.
id imagine they would do everything for you, ie. remove, re-build, then install your engine so it would be pretty much drive in drive away.
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
i rang them they said $8800 for the engine rebuild but they told me to ring a mechanic for labour costs on pulling out the engine? im confused there.......
a mechanic will probably charge you $1000 for taking out the engine and putting it back in. While spending all this money you better replace the knock/oxygen sensors, all the pulleys, new radiator
It takes COME about 2 weeks to strip your engine and build it again so I hope you have another car to use
btw whats the details on the stroker did he give to you?
ooooo wee! stroked eco-tec aye??
how much kilowatts does it pull out at the wheels?
depends what you pick, likewise cam, heads, compression ratio
nah its not an ecotec........ecotec came out on the vs.........
he didnt give me many details on it just yet i just wanted a quick quote while i was on lunch at work..........yeah i can borrow dads VX wagon cos he drives his new rodeo to work..........*notes down knock+oxygen sensor radiator and pulleys*
would C.O.M.E be able to hook that stuff up for me at an obvious extra charge? or cant they be assed doing all that shiz?
but i still dont understand why C.O.M.E asked me to ask a mechanic how much it would be to pull the engine out? wouldnt C.O.M.E be doing that?
nah they dont do that work, they basicaly expect the engine there in a crate. So you or your mechanic have to send it to them.
ah i see.........****house..........this may cost me more than i thought.........*hates to think of what the frieght will be on sending a bloody buick engine from burwood to caulfield*
hahahahaha what needs to be done needs to be done though!!!
when I install microsoft word again later tonight i'll give you the details and prices of the strokers that Sam gave to me
COME pays for the freight![]()
I had to send my engine back 2 months ago, I snaped a lifter in half and left the bearing in the engine I would of loved to see the freight cost lol
thats pretty gay, i would have assumed c.o.m.e could do it all for you, lazy bastards.
basically what you need then is your mechanic to remove your engine and send it to c.o.m.e. (which then means your car will be sitting around his workshop for 2-3 weeks)
then when c.o.m.e have finished they'll freight it back, and your mechanic will need to put everything back in. id budget $2k for your mechanic, just to be safe, plus you'd likely replace alot of old gear too - sensors, pulleys, belts, and what ever else is unconvered to need replacing ontop of the labour charges.
im not aware that c.o.m.e organise/pay for freight TO THEM, but i do know for sure return freight is included in the engine build cost. i didnt sent my engine to them, so i dont know, i just bought a short block off them outright.
maniac will know for sure what they do though freight wise and everything, he did the whole hog.
But the freight wouldnt cost much anyway as you are both from Melbourne. Just get a courier, it should cost at least $100
I remember getting my VL up here from Adelaide which only cost me $700
I think your right mine was a warranty job so I didn't pay nothing for it to be repaired
ill have to talk to them and my mechanic tomorrow and see if my mechanic is willing to have my car sitting around his yard for 2-3 weeks...........im sure there wont be a problem as he is making a fair wad of cash off it........he will probably charge me extra though
If i could just put my two cents in i wouldnt buy a come engine these days, theyve been resting on thier laurels now that they've made it. Ive had to send cranks back due to problems.
If your after high quality machine work/stroking etc i'd go for Auscrank.
31-35 Cottage St
Blackburn VIC 3130
Melbourne, Australia
Ph (03) 9894 0000
http://www.crankshaftrebuilders.com....rebuilders.htm
ya come pay freight as i sent my engine down cost $9000 all up for st.3 ecotec 4.2
