Results 1 to 21 of 21
Thread: Timing on Red 173!
    VN V6 Manual
    Mar 2007
    The South
    Default Timing on Red 173!
    The car didnt start up this morning, and I have been having problems with it like that a fair bit. Spark there from the dizzy, and fuel fine... definately timing I think. Anyway, I got a guide from oldholden.com on how to do it, since most of my other cars have been really straight forward I thought id just rip out the dizzy and redo it 'properly'.
    Retiming engine from scratch link from Oldholden.com
    As I rotated the crank, Cylinder #1's inlet valve opens then closes and the guide says that at the end of the close the dizzy should be on TDC, so rotate the crank to 6btdc and then set the dizzy to fire Cyl#1.
    The mark on the crank pulley however is totally out of line from this, and going either way from that mark while turning the crank doesnt do nothing to the inlet valve.
    Tried this with the vacuum advance module plugged in and not... still nothing.
    Running a 173 holden red engine w/ electronic ignition.
    Edit: On the timing cover, there is TDC, and some major notch anti-clockwise to that, and about four notches clockwise with an R above them. I figure this was timing retard and the notch to the left of the TDC mark is something I have no idea.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The notches run in 2 degree increments. You want to align the mark on the harmonic balancer with the 3rd notch to the left of TDC which is 6 degrees BTDC. Do this with a timing light while the engine is running and the vacuum line disconnected from the distributor. To get the dizzy lined up correctly, rotate the engine until number one piston is at the top, number 5 valves should be rocking, that is the exhaust and inlet will be see sawing when you rock the crank back and forth. The rotor button should be pointing pretty close to number 1. If not, take the dizzy out and rotate it around a bit. If the mark on the harmonic balancer is not lined up with TDC the it has probably spun on the rubber. You will need to get a new one to set the timing accurately, or you can mark the position on the balancer to set the timing until you can get a new one.
    VN V6 Manual
    Mar 2007
    The South
    Cheers, Ill get the spark plug out of cylinder 1 and use something that wont damage the piston to find TDC?
    Cars not running, been having problems so I just took out the dizzy and tried to set it fresh. Do I plug up the vacuum line going into the dizzy? And the other end into the manifold? I can buy a new balancer, thats no problem. I have to pull it off to change the timing cover gasket there anyway this week. Putting a complete new gasket set through it.
    1989 VN 5 Speed – Turbo conversion
    1997 BMW E39 M52B25 Powered.
    1994 Yamaha XT225 Modified
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You can put a screw driver in there just don't let it jam as the piston rises. When the piston is on the comression stroke you will hear pressure escaping from the plug hole, you can put your finger over it to be sure. If you don't feel pressure then it is on the exhaust stroke and you will have to go around again. The vacuum line goes to the inlet manifold, when checking the timing, you just need to block the line going to the manifold, not the fitting on the dizzy.
    VN V6 Manual
    Mar 2007
    The South
    Sweeet, thanks alot for your help. I'll get at it in the morning. So the crank spins anti clockwise right?
    Just turned over the dizzy and it spun clockwise, and hand turned the crank anti-clockwise to make the dizzy turn clockwise, so I figured it out like that...
    Fingers crossed =)
    Also while Im at it, im putting a complete gasket set through it 2moro... is there anything else I should do while im doing it? I know there are things like this with alot of cars. Going to replace balancer, fan belt... stromberg is blackish inside, bit of leakage, so thats going the week after for a 350 Holley. Car has a 2.25" Exhaust w/ single Walker muffler at the rear, extractors going to be fitted when holley goes on.
    I have no idea of the power of this engine. Just read it was like 80kw~ or so in a few places. Would shaving the head significantly raise the compression? My mate has a high compression LC 202 Red engine 350 holley/extractors/yella terra head (points ign, mech fuel pump... whereas mine is elec fuel pump and elec ign) and his cars exhaust pressure is ALOT compared to mine. My car goes hard for a stockish 173 though.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Looking from the front of the car, the crank spins clockwise. Shaving the head will give it more compression but unless you port the head and fit bigger valves its not much point. I would give the holley a miss too, IMO they are heavy on fuel for the power gains they give. A popular carby for the reds is either a Carter, or a Webber from an XE or an XF. There isn't much you can do to it apart from extractors and exhaust and carby without spending a heap on it. Remember its only a 173, try to get your hands on a 202. All the bits will swap straight over.
    VN V6 Manual
    Mar 2007
    The South
    Yea the 202 would be the go, but if im going to do an engine change its definately going to be a 308. Staying with the old man at the moment and he doesnt want me really working on cars here that much. Engine cranes and conversions even for one day would make him go mental and kick me out. I been looking at the XE/XF webber's and wondered what I'd have to do to make one fit. Id personally rather one of them then a Holley, alot cheaper and can find them everywhere.
    Also with the stromberg now, when I put my foot down, it really doesnt like to go. Wont kick from third to second, although shift from second to third is really strong (Possibly the kickdown cable I reckon... gotta check that 2moro)
    And after that the car probably floods and just runs like crap, overheats if its hot and starts chuggin along.
    I upgraded the cooling system, and now am using a VR radiator and massive thermofan which I just keep on all the time, running off a switch. New thermostat and housing, custom hoses etc... just trying to make it reliable before I do anything to make it faster. However removing the engine fan and making it run cooler helps alot. Also have CAI pipe going from stock air cleaner to under the front bumper. Oil going all over it though... cant wait till about two weeks time.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'm pretty sure you can get an adaptor plate for the webber.
    Sounds like you have a project on your hands, good luck with it and keep us posted on your progress.
    VN V6 Manual
    Mar 2007
    The South
    Will do, cheers for the help. Now to find a nice shmick new digital video camera to take some pics. Old man's car got broken into while he was in asia and his got stolen =(
    Just did my research on the webber carbs, and they seem really nice and what I want.
    VN V6 Manual
    Mar 2007
    The South
    Quote Originally Posted by Not_An_Abba_Fan View Post
    The notches go to the right, and after finding TDC with a screwdriver, the harmonic balancer mark sat right on notch #3. The dizzy was out of line to this at the time, so my hope raised slightly.
    I set the dizzy so it was firing right on piston number 1, plugged up the manifold vacuum line and started her and nothing still. Not even a cough and fart.
    Im thinking there is some wear on the cam etc? I read about it somewhere... the dizzy shaft looks mint. However because TDC sits on where 6BTDC lies... does that mean I need to go another 6BTDC backwards??? I'm thinking that is the problem.
    The fuel pump is doing its job... the carby is pretty dark in there, and I didnt pay too much attention as Im trying to bog the car up also, and that is taking priority over me starting it up. I have to start her up by the weekend though, because I have to start work again on Monday. Did the rocker cover gasket today also =)
    If its a problem with the carby or fuel, which I dont think it is because it should be coughing and farting even with no fuel, right? Then im going to fit a webber carby from an XE/XF. Ill be doing this in a week or so time anyway.
    VN V6 Manual
    Mar 2007
    The South
    Quote Originally Posted by Post Vintage View Post
    ...because TDC sits on where 6BTDC lies... does that mean I need to go another 6BTDC backwards??? I'm thinking that is the problem.
    Been told this IS the problem!!! That's what I thought... never knew the engine could throw out as far as that.
    VN V6 Manual
    Mar 2007
    The South
    Had to pour petrol down the carby... this is the problem now. Car started and ran fine after adjusting the timing properly and pouring fuel down it.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    So it runs ok on its own now? If you have to pour fuel in the carby to keep it running then maybe the needle and seat in the carby is sticking. They are in the brass fitting that the fuel line screws into.
    VN V6 Manual
    Mar 2007
    The South
    Nah it run ok before I pulled out the carby... took the thing apart and cleaned it out, and now it just floods the engine with fuel and pisses all out everywhere down the manifold.
    Its cheap enough to buy a new carby, just I cant find many places for the $20 Im prepared to pay for one lol...
    I tried to stick some thin wire through one of the holes to see if it was blocked up. More of a probe rather than an unblocker, but Im not sure if I damaged it or not. I forgot all about pickapart!... Might see what they want for a carby. Lost one of the rocker cover screws also, and little pieces here and there I can get hopefully.
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Carbies can be a pain if you're not sure of what you're doing. Good luck.
  16. #16
    VN V6 Manual
    Mar 2007
    The South
    Yea totally, just going to get another one...
    Pickapart reckon $50 for one...wtf no way.
  17. #17
    VN V6 Manual
    Mar 2007
    The South
    Cant find one at any wreckers... they are like $10 on ebay but I owe $20 worth of fees which I posted yesterday so can't buy them, and need them this week... doh!!!
    I got about $50 on me today, and need some fibreglass repair kit, so maybe I should just stick with doing bodywork today, and go get a 350 Holley for her 2moro....
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Please....no. 350 Holley is worse if you don't know how to tune it. Also, all it will do is use a bucket load of fuel. Go the Webber.
  19. #19
    VN V6 Manual
    Mar 2007
    The South
    carb - 30+
    manifold - stock 350 manifold - $30-50 if i can find one
    adaptor plate - $40
    Holley 350 and manifold - $100...
    Ill go withdraw $300 out my account on friday so I can work on the engine over the weekend. Need the car for Monday morning, and the holley is basically standard fitment. I have some experience with the 350 Holley on 202's so it should be roughly the same. Enough to get it running anyway. My uncle can come tune it for me properly. He was a mechanic for ford for 35 years until he retired a couple years back.
  20. #20
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    We have a 202 with a street stock cam here that I have been playing with. We fitted a brand new 350 hooked up my wideband & put it on the dyno. Standard 350 holley jets are too big for this combo & we had to go down to #57s on the jets to get WOT fuelling close. The 173 that you have will need smaller again. Especially since it is for the street.
  21. #21
    VN V6 Manual
    Mar 2007
    The South
    Yea I have heard many people say the 350 Holley is too large for the 202's.
    I just got a red 202 engine and box for what I could of got the holley for. Just going to run the stromberg for now, save money on fuel and rebuild the 202 with new gaskets, do some head polishing and intake manifold polishing, lumpy cam and extractors on my already 2.25" system... should run nice then.
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. Timing
    By krisjanik in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-11-2006, 09:21 PM
  3. cam timing
    By aghatas in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2006, 08:30 PM
  4. vs v8 timing help!
    By mean in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 03:52 PM
  5. timing
    By vn series 1 owner in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-06-2006, 07:50 PM
