Can I block the coolant lines going to the intake manifold without any problems? I figure this water is like 90degC and wont do too much to the intake manifold as far as heat is concerned, will it? I have a massive VR thermo on there and good cooling system, VR radiator etc so surely it should be ok. Dont see the need for it.
1989 VN 5 Speed – Turbo conversion
1997 BMW E39 M52B25 Powered.
1994 Yamaha XT225 Modified
what are you actually trying to do
cool the motor?
if so run a 81o thermostat
factory they 91
dont run it too cool
Shouldnt be a problem mate as it is only there to warm the intake charge. Having a warmer intake charge helps in cold conditions as it aids fuel vaporisation & combustion. BTW the non crossflow design will heat up the intake charge heaps anyway.
That exhaust wrap should help me out a bit there shouldnt it? Ill block the lines off because in my old 202 this is what was done, same as my HJ but that had a holley carby. I think looking at cooling that engine before working on performance should be a priority. Also a 80deg thermostat is the go... since I have the VR radiator and thermo now it should keep temps down. Lots of pressure in those old holden engines.
