Wondering if anyone has done a VS engine change and had any dramas.
I had a snapped cam in my VT and put in a VS V6. I've changed over the injector tub etc. and now the engine kicks but wont run..... I disconnect the Airfow and TPS etc. and it is still the same, I also try it with a bit of throttle but no difference,anyone else had this problem????????
the engines should be the same, you getting any error codes?
Body by Holden, Soul by Brock
the Legend will live forever
u may have an air lock in ur fuel rail..
y did u change the injectors n fuel rail? i have a VT engine in the VS, jus dropped it in n pluged it up, n didnt have a drama..
check ur codes as immortality has meantioned
Make sure you have plugged everything in. Sometimes it's as simple as leaving one plug disconnected.
