Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: How much power can a Getrag 5spd Handle
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Default How much power can a Getrag 5spd Handle
    I got a VXII 5spd S-Pack and i am toying with the idea of charging it...
    Roughly 200rwkw.
    Just wondering if the gearbox will handle this?
    I drive the car pretty hard..
    I also plan on putting a LSD 3.7 in and an exedy HD clutch to strengthen the driveline abit...
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i hear that are pretty crap but thats just what i hear i never owned one.
    Could be a good time to get a tremec T56
    We got rep back, yaaay!
    VT V8 Calais
    Mar 2007
    I would be intrested to know this too, I want to convert my vt 5ltr calais to manual and as I understand it the getrag was the box holden used for this model.
    I would like to know how much power it can handle to plan for engine mods after the conversion
    50LTRv8
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    See thats what im thinking...
    They put this think behind 5lt VT V8s so it can't be all THAT crap...
    And from my understanding the 195i VT 5lt still ran the same box except for a different 1st gear ratio...
    1983 VH SL 3.3 Litre 5 speed, 2002 VY Executive
    Feb 2007
    Burnie, Tasmania
    I read some where that they ran getrags in the old ATCC tourers, if thats true they should be able to handle 400+HP
    F.O.R.D
    Forget Out Running Datsuns
    '00 WH V6
    Dec 2005
    Don't do it! lol
    It can handle a pansy 5L, but it couldn't handle the L67 (hence it was only ever released with an auto). The one person I've read of doing a manual conversion broke a stock T5 in all of 3 months, had to do some strengthening to get it happy.
    If you're aiming for bigger numbers, you'll have to look at something that can handle a bit more power, especially so if you're looking at charging it (which involves massive torque right from the bottom=bad for gbox).
    Driving a CURSED WH V6.
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    and expensive dual mass flywheels too, replace a clutch, replace the flywheel too
    VT V8 Calais
    Mar 2007
    As I understand it the getrag box is not the T5, the T5 is a borg warner box and the getrag is a german made box?
    Is this correct?
    50LTRv8
    Quote Originally Posted by mattman View Post
    Don't do it! lol
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    I thought the getrag was made in china? I like the box it feels great and i give mine hell and yet i havent hand any issues, in saying that i would advised a fully Synthetic oil then drive it hard for a week and then replace oil with new Synthetic. Im also looking into a rip shift as the gear stick seems real sloppy when in gear, like its missing a rubber to tighting the gears shift up.
    .:Blown VT V6, DAJ37:.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    VY Acclaim S1
    Apr 2006
    Perth, WA
    Quote Originally Posted by Jesterarts View Post
    Damn, how much effort is it to put a t56 onto a ecotec??
    i want to know this too, and if its possible. cant seem to find an answer from anywhere so if you find out id be keen to know.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    PM BlownVs for exact numbers
    But he was running a turbo on his, and with more than 200kw at the rears, held up perfectly fine.
    The clutch however, always seemed to play up when Skye was driving, wierd that
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Is that 200rwkw with the Getrag or the t56?
    Pretty impressive if the gertag held up with 200rwkw!
    Yeah, the clutch would be sumfin to upgrade probably...
    im gettin slippage atm and thats only running about 170ish at the fly!! lol
    fmlycar's Avatar
    fmlycar is offline 6appeal
    308rwkw 180sx
    Oct 2006
    Alice Springs
    I think there is a black VY ute V6 on here that is running 355rwhp through the getrag M35. I'm sure with a decent clutch you won't have too many problems. Maybe look into a short shifter with positive stop to reduce over throw and rooting the syncros.
    As for your slippage, I would put that down to crap factory clutch. When you upgrade your clutch you will have to replace the flywheel as well cause the getrag run a dual mass flywheel from factory.
    When you see a car that's BLOWN it's refering to the budget.
  15. #15
    STEALTHY™'s Avatar
    Jan 2005
    The box is the standard box used on a series 2 VS V6, so i assume thats the getrag, not the T56. (haha, it was only a 5 speed, so of course it was)
    The clutch wasn't standard tho. Like i said, PM BLOWNVS and ask him the specs, cause i only drove it, never worked on it.
    cheers sexy
  16. #16
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    The life of the Getrag seems to have less to do with outright power than with abuse. A customer of ours has been hard on his and yep destroyed 1st gear, however no one else has yet so I suspect it more driver related than power related. We have taken the precaution of informing people there could be an issue but maybe we are being mislead by just the one instance we know about at this time.
    Hope that helps
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  17. #17
    VU Storm
    Jan 2006
    So if you stop dropping the clutch from 5grand it should be ok?
    How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
  18. #18
    fmlycar's Avatar
    308rwkw 180sx
    Oct 2006
    Alice Springs
    Make sure you got enough oil in the box too. From what I know and have experienced the M35 will use oil. Look after it and keep it serviced and you should be fine.
  19. #19
    VU Storm
    Jan 2006
    Would ther ebe any hassles in changing to the t5 from a getrag?
  20. #20
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    im guess ing just an adapter plate... not even that...
    Cause the VS ecotec 5-spd had the t5...
    Yeah, i don;t often find myself dropping it from 5G lol!!
    Once in a blue moon of the lights i light them up from about 3000rpm
    But i regularly drop it into 2nd @ 4500rpm... that would probably kill it...lol
  21. #21
    VZ SS 6 SPEED MANUAL
    Apr 2007
    WA
    Roughly 200rwkw.
    Hey mate, when i first got my VV manual, i use to hell give it a beating, exspcially the 1st to 2nd chrip, and it held up pretty good aye
  22. #22
    Apr 2007
    WA
    Roughly 200rwkw.
  23. #23
    VT SS
    Aug 2007
    HoldenManDan's Avatar
    HoldenManDan is offline Built, not bought...
    VS Exec SII 4.2L L67 T56 :D
    Jul 2006
    Penrith, NSW
    Hey mate the VS SI Manual had the T5, the SII has the getrag, just thought i'd clear that up for ya
    So are ya gonna charge your VX or what? My VS will be hopefully sometime in '08, i reckon looking into whats involved with dropping in a T56 would be worthwhile. I saw one on ebay a week or so ago for 2K, came with some extras and only had 26,500 k's on it. Hopefully they wont be too hard to swap over!
    vr 3.8lt executive
    Jul 2006
    what supercharger are ya going for?
  1. getrag and flywheels once & for all
    By mattyr82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2007, 09:04 PM
  2. GETRAG suit VT V6
    By buzurk in forum Swap / Wanted to Buy / Trade
    Last Post: 27-08-2007, 05:41 PM
  3. F.S. VT v8 getrag g/box
    By madmartian1 in forum Parts And Other Items For Sale
    Last Post: 02-10-2006, 10:21 PM
  4. F/s V6 Getrag
    By ADZ124 in forum Parts And Other Items For Sale
    Last Post: 21-04-2006, 02:10 PM
  5. VY V6 Getrag Oil quantity ?
    By OZ38 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-02-2005, 12:24 PM
