Results 1 to 21 of 21
Thread: t5 gear box
    Oct 2007
    Default t5 gear box
    can i bolt a 6 cyclinder t5 box to a v8 with just changing the bell housing
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the input shafts are different i believe.... can work with a custom made spigot tho. just need to ahve one machined to size for the crank diameter and the input shaft diameter
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    The V6 T5 is not as strong as the V8 though... there is a differnece betweent he boxes.
    The V8 input shaft can be machined to a shorter length to fit into the V6.
    With the price of V8 T5's, i can see why your asking!
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the V6 T5 box has different ratio's also. Greenfoam recon's it faster also then the V8 T5 box.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VN Commodore
    Feb 2006
    i am pretty sure the box's have the same bearings and are not any stronger or weaker. there is some stupid number of different versions or t5's. i think ya can just change the imput shafts to suit your motor
    anyone ever finds some info in these box's it would be good. then there woudln't be any specualtion..
    Boonz's Avatar
    Jul 2005
    there was 3 different boxes i know that. the V8 one was the same but there is 2 different V6 ones, series 2 VR's onwards have a different shell to the earlier ones
    VP Executive R-spec
    Jan 2005
    Besides the bellhousing and the fork (the v8 one is the same fork but has no weights on it) The V8 T5 has longer and less optimal go fast ratios but the long first gear is supposed to be a bit stronger just because of the ratio on the thing. I think in a VN or VP or anything else lightish it would be just fine though. In the states and England race cars are runing T5's with straight cut gears that are rated for over 600hp, expensive but good since you still have yourself a 40kg box . The input shaft is an inch longer on the V6 than the V8, you can either make an adapter or cut the shaft. Both box's apart from the ratios are the same and are both the "world class" style T5
    VN Commodore
    Feb 2006
    the different version i was talking about are with all the different vehicles that use the t5 and there variations in each vehicle. it would be interesting to know what else they were used in. we know ford and holden used them. and greenfoam has metioned us and engish race cars.
    a mate of mine has a trans-am with a BW 5 speed so i would be thinking that is a t5 too
    VU S Ute
    Nov 2006
    Penfield SA
    The Holden V6 T5 will fit behind a Ford 6 or V8 or vise versa. The Holden V8 ones only fit Holden V8's.
    I was told once that the older T5 eg VP was stronger than the VS style one as it did not contain reverse brakes inside the box, less bits to go wrong.
    I have a recon V6 T5 for sale
    Life without challenge........ May as well be dead !
    Watch out for the Two Tone ute terrorising a city near you
    Raptor Superchargers... More than just a good Blow Job
    VP Executive R-spec
    Jan 2005
    The Ford boxes have a different case but the insides of a Ford T5 can go inside the Holden case or you can just have an adpater
    Apr 2006
    Auckland NZ
    there will also be variations of the extension housing to suit different applications to get the shifter in the right spot etc
    Mar 2007
    Question
    will a vs t5 fit into a vn as im looking at puschasing one soon and wouldnt want to buy it and find out its no good to me?
    VU S Ute
    Nov 2006
    Penfield SA
    I have a rebuilt one from a VP that will
    VX SS II 6.3L/M6
    May 2005
    How strong are the T5 V6 (VR S1) gearboxes? How much power can they handle? Is there anyway to upgrade them...?
    VS commodore executive
    Jun 2009
    i need to know if a VN 5 Speed box will fit into my VS series 2, my auto is dying and it is cheaper to convert then to get a new auto. making it a project car and have big plans, but need to get ovey this hurdle first, if anyone can shed some light on it it would be a great help.
    cheers
  16. #16
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Yeah it should be fine. I was in the same position as you but used a VR T5 which just has slightly different internals. You will need to make sure you get an 8 bolt flywheel though. VN series 1 had a 6 bolt.
  17. #17
    vs commodore
    Jun 2010
    Default t5 gear boxes
    Hi i just brought a vs commodore v8 with a auto in it,um i need some help in choosing a t5 gear box,what do i need in order to complete or convert my car into manual?thanks
  18. #18
    VK-V8's Avatar
    VK-V8 is offline Mati
    1984' VK V8 5L, 5 speed
    May 2010
    Canberra, Australia
    Question Gearbox
    Hello!
    I just picked up a T5 Gearbox from a v6.
    I have a 304 V8 with a T5.
    it is noisy in 5th gear...
    Can I install the v6 T5 onto the 304?
    just change over the bell housing?
    Cheers!
    RtR - Ready to Ride!
  19. #19
    car
    Jul 2006
    greensy, melb
    if you have a read of the rest of this thread you posted in then you would find that no you cant, its not as simple as that.
    "A life lived in fear is a life half lived"
  20. #20
    VK-V8's Avatar
    May 2010
    Canberra, Australia
    Question Ok
    Ok,
    Is it possible to take out the input shaft from my V8 T5
    and put it in the V6 T5?
    What else is there?
  21. #21
    car
    Jul 2006
    greensy, melb
    could work. ive never had a t5 box open so not sure how the input is attached to the main shaft, if all works and you can get it in the gear ratios will be a bit different
  1. Vt Gear Box?
    By XCALBR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 07:13 PM
  2. Redline 1st gear & 2nd gear...weird
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 09:02 PM
  3. 4th gear O/D 4th gear not working in vr
    By nathsvrbt1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 12:17 PM
  4. need some help on a vp v6 gear box
    By vk_wagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 12:15 PM
  5. UK Top Gear and Fifth Gear Episodes
    By oblong in forum General
    Last Post: 25-02-2005, 09:34 AM
