Results 1 to 2 of 2
Thread: fuel pump trouble
    vn calais
    Jan 2008
    Default fuel pump trouble
    ust changed dash, aircon,and wiring loom from my v6exe to v6calais ive got every thing working but there is no power to the fuel pump, iv'e checked all fuses and relays and i have tested the pump and it works doe's it have anything to do with the imobiliser overide switch that has been riped out? or if any one has the wiring diagram for the fuel pump, could you send it to me any help would be appreciated
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    check this link for wiring diagrams
    Rob's Creative Calibrations - Wiring Diagrams
    the pump gets it's signal from the PCM, it should turn on for a few seconds when you turn the key to the on position and then stop. once the engine cranks and starts then it turns the circuit on again. have you checked the fuel pump relay and fuse?
    there is also and output on the diagnostic plug for the fuel pump, however i can't remember which pin it is. if you put an LED on this output on the diagnostic plug you can see if the PCM is turning the circuit on.
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Vs Ute Fuel Pump Trouble!!!
    By Utephoria in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2009, 07:59 AM
  2. Anyone else having trouble with BP fuel at the moment?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 02:30 PM
  3. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  4. Fuel trouble? pump won't switch off
    By MickDuprez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 07:03 AM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
