Hi all, did a quick search and couldn't come up with anything directly.
I was told the other day that if you take the plastic engine cover off it can give you a bit more power as it helps the engine remain cooler, a few blokes at work have done it and seem to think it helped but not sure if i want to as my cars still under warranty and not sure if that'd affect it at all.
Cheers, Ryan.
engine cover is only held on by 4 bolts or so, wont affect warrenty at all.... wont give u any power at all just make it cooler but more air flow, engine covers just attract more heat...
Cheers, thought they were dreaming a bit when they said they gained 5kw.
The heat thing makes sense though.
yeh i knw the vz ss 5.7 covers clip on, but hes got a sv6 so im assumin ther bolted??
+ is they keep it lookin tidy![]()
benefits of leaving them on, visual / saves cleaning the engineand apparantly they "reduce" engine noises
