Results 1 to 8 of 8
Thread: VT Mini spool, clunking??
    VT Super6 S-PACK
    Jul 2005
    Country boy in Magil
    Default VT Mini spool, clunking??
    Hi every one i fitted a mini spool to my car last night and now im getting a bad clunking under very hard aceleration or wheel spin, the same sort of feeling you get from doing a burnout in reverse. I marked the screw adjusters before removal. Just wondering if any one has had this issue before.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Do you mean axle tramp? :S get a mate to look @ your wheels when you take off hard/wheelspin and see if they're bouncin' up and down like a mad man...
    VT Super6 S-PACK
    Jul 2005
    i dont think its that because if i nail it from 40k it does it, but il get my mate to watch 2mrw night
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    cracked diff cradle? or is that only a problem on earlier IRS commodores?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    it might also be u havent set the axles in the right position or not tightened everything up tight enough dunno just a thought
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    VT Super6 S-PACK
    Jul 2005
    Ive checked every thing is tight. If the backlash is to tight could that cause this, it feels slightly tighter than a normal diff i know its deffinatly not too loose. Also are 3.08 gears timed, or does the crown and pinioin line up in any location
    Apr 2006
    Auckland NZ
    in an ideal world you should have marked the gears so that they line up on the same teeth again. however not doing this won't result in a clunk, maybe some gear noise but not a clunk. a clunk indicates something is either loose or moving when under load.
    minispools are natoriously hard on suspension bushes, if you have any that were in poor condition with the standard diff, fitting the minispool will show em up straight away. you mentioned it did a simmilar clunk when doing reverse burnouts i'd suggest the problem was there before however with the standard diff it wasn't creating enough load under "normal" conditions to cause the noise
  1. Mini Spool
    By vs_ss_matt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2009, 01:39 PM
  2. F.S Mini Spool
    By AnthsVSLexcen in forum Parts And Other Items For Sale
    Last Post: 18-10-2007, 10:02 PM
  3. mini spool
    By Egnitevt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-05-2007, 05:28 PM
  4. Spool/Mini-Spool VS LSD
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 08:14 PM
  5. Mini spool -irs
    By stumps5L in forum V8 Development and Modification
    Last Post: 08-12-2005, 05:06 PM
