Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: water injection
    car
    Jul 2006
    greensy, melb
    Default water injection
    -just wondering how water injection works
    -how much power gain there is
    -and how to set it up
    any info would be great
    "A life lived in fear is a life half lived"
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    water injection works just like an intercooler, the water absorbs the heat cooling the intake charge. it has the bonus effect of steam cleaning your engine from the inside.
    Body by Holden, Soul by Brock
    the Legend will live forever
    vn calais, vs clubsport #137
    Jun 2005
    car
    Jul 2006
    greensy, melb
    so how is it set up and where? is it before the throttle body?
    weedo_86's Avatar
    weedo_86 is offline JC Resident FireFighter
    03 VYII Clubby M6, 92 Barina With Sunroof :)
    Feb 2006
    Melb, Vic
    i got a set up to go on my charger, it injectors a fine mist before the throttle body
    DVLHSV Stage 2 is Now in Operation
    My VYII Clubsport http://forums.justcommodores.com.au/...clubsport.html
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    cooling the intake temperatures is a benefit of water injection but the main reason is to increase compression in the combustion chamber, not alot of power is to be made with a water setup but works wonders on a worked motor.
    Apr 2006
    Auckland NZ
    Quote Originally Posted by vn calais manual View Post
    begin: the water injection vs intercooler argument =)
    i don't see it as an argument. each has a purpose and a fuction, to achieve a similar end result. intercooling is only really suitable for FI setups as it is used to reduce the heat introduced by what ever means fo forced induction your using. water injection can be used with either FI or N/A. the great thing with water injection is that you can also mix it with alcohol (50:50 mix) for good results
    89 vn v8
    Sep 2007
    pretty sure the army used water injection in their tanks and planes in ww2.
    mechanic recons it works well although you
    need a good set up which he says is just over a grand .(with computer mods ect .
    there were kits out there but most are apparently crap!..with small gains.
    must reserch!!
    VH and VT S2 Berlina ecotec
    Aug 2007
    Brisbane-northern suburbs
    i have no idea how water injection works...last i heard water in the engine is bad...sorry for being noob lol
    Apr 2006
    Auckland NZ
    Quote Originally Posted by com8 View Post
    must reserch!!
    yes, they used water injection in WWII fighters. it was forgotten about after the war but has become more popular in recent times and from waht i've read about it, it definitly does work, in fact one guy questioned why it wasn't fitted as standard from the factory, i guess the manufactureres don't want there engines to last forever
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I was of the understanding that water injection was mostly an injector in the inlet manifold, and as its sucked in heated and compressed in the cylinders with the air and fuel it splits and burns, thus giving a very small power boost as hydrogen and oxygen are much more flamable than petrol and cleans your engine slightly and helps to rust your exhaust a bit quicker.
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    Quote Originally Posted by kniever View Post
    water injection cools the intake charge and helps avoid detonation. it doesn't raise compression itself, but allows the engine to run higher boost or engine compression ratio (which normally means skimming the head).
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Quote Originally Posted by VrWagz1 View Post
    a tiny bit of steam should be comming out of the exhaust anyway its normal for moderns engines, not to mention that the exhaust after a long drive is generally hot enough to evaporate it away, this is why cars that do allot of short trips and very few and far between long trips tend to end up with rusty exhausts, at least thats what we were told when my dads AU ended up with a rusty exhaust.
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
  15. #15
    Black VN MANUAL
    Feb 2007
    Top of Vic
    hey guys, i just got a SC-14 CRS kit on my car and the previous owner of the supercharger had water injection but hooked up to the inlet of the charger so it sprays into the charger, somehow i dont think thats good, could i get a plug up near the T/B about 3inch away from it and hook up a mister in there would that help? and hook it up the a washer bottle, i was also thinking of having a micro switch around the other side of the T/B so when its at full revs it will put the mist into the T/B is this a good idea, i'm abit iffy about the set-up i dont want to stuff anything up, and would there be gains to be made by doing this, i'm only running 3psi any info is great cheers
    ~ VN POWER ~ Click the scales
  16. #16
    car
    Jul 2006
    greensy, melb
    from what ive read the washer bottle is a handy idea for the water but it runs out too kwik, ive seen a few peaople use a bigger container in the boot so they dont have to fill it as often
  17. #17
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    3psi i doubt there's any need for it. The only good thing about being on the intake of the charger is it should drop inlet temps by a fair whack better thanhaving it in you manifolrd tb area. As to whether its good for the charger i don't know. But they are a sealed unit so i don't think there's much chance of it getting into bearing which would eb the main worry
  18. #18
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    thats true - i dont think many people even realise that the cat will convert hydrocarbons into water and carbon dioxide. so water in the exhaust is extremely normal - as you said though, its that damn hot that it evaporates almost instantly, after all the cat operates at a few hundred degrees.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
  19. #19
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    ya wont get mist / fog spray from a jet thats into a washer bottle
    ya have to get the proper pump and nozzle to make it into a fog then it cools down the washer bottle just doesnt have enough presseur to pump and atomise any liquid
    also without a checkvalve youll find your water will be sucked out into motor even at idle cause vacum will draw the water up
    at 3psi it wont make any diference
    water injection doesnt give power it only cools to stop pinging
    i run methanol/water
  20. #20
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i have something simular to what you have its the size of a coke can and pumps water really far but making it into a mist with alot of pressure may make the pump die lol, thanx for the info guys.
  21. #21
    Black VN MANUAL
    Feb 2007
    Top of Vic
  22. #22
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    just wondering if the capa water injection kit is worth buying for my vx raptor supercharger set up?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  23. #23
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    how much are they i got my kit off [cooling mist ] ebay usa. cooling mist sell them on there it was 300 to my door i think i would have to check
  24. #24
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    i brough a brand new capa kit off ebay yesterday for $200 normaly $475 plus
  25. #25
    VP Exec
    Jun 2005
    Quote Originally Posted by immortality View Post
    Didn't SAAB and even before that Chevrolet on the Corvair fit water injection? I think the issue would have been owner's neglecting to fill the system and killing a motor tuned with it working.
    Quote Originally Posted by Bz Kn33z View Post
    The received wisdom is that with a (low speed) positive displacement blower the water can help tto seal between the rotor(s) and the case, lifting blower efficiency and upping boost a little. Not so good on a centrifugal blower where the high rotor speed has been known to result in effects akin to a water cutting jet.
    Julian Edgar on Autospeed (and in a few hard copy publications) has written a lot on water injection, which may be worth look. Water/methanol injection is pretty popular with the turbo buick Regal/GN boys and girls in the states too - that will be worth a search, as would "Aquamist".
  1. Water injection
    By 10000_fists in forum V6 Development And Modification
    Last Post: 22-04-2007, 06:59 PM
  2. water injection on a turbo v6.. hello VP_LUKE...
    By defa in forum V6 Development And Modification
    Last Post: 03-12-2006, 12:28 PM
  3. Intercooling vs water injection
    By VNV6VENGEANCE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2006, 10:32 PM
  4. Vk DIY water injection
    By AuWozza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2005, 05:20 PM
