Results 1 to 13 of 13
Thread: mystery miss, please help me!
    Jun 2008
    Unhappy mystery miss, please help me!
    Gday guys. My name is Morgan and I work in a small workshop. The reason I'm asking for help is that I serviced a VT commodore 99 stock standard 3.8 and ever since it has had a miss. The miss is more evident in drive and it's not a constant miss. When you experience it, it makes you think it's the coil.All I did in the service was plugs, fuel filter, and oil and filter. The only thing I did do wrong was mix up 2 leads which was a stupid mistake. Since the service I've been chasing this problem by replacing all the leads in case I'd cracked a plug, replaced all leads, tried 3 brand spanker coil packs, o2 sensors, scanned it for codes and nothing comes up. Soon after the service I was chasing this problem and gave it a tk test for the head gasket and it was positive. We did the head, had them serviced and all, put them back on and the miss is still there. I am out of ideas and curious as to why it's doing it. We had the same problem with another vt commodore wagon. Same type of miss. car drove fine once u were driving. Wouldn't notice a thing. So if anyone could shed some light on this you'd be a great help!
    Cheers.
    Morgan
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    have you tried different plugs one might be defective from new all-all it v6 and they do it at one stage or another dfi module might be worth checking too
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Yeah as Pub24/7 said, DFI and plugs. I would start with the plugs, a few brands are well known for quite often having dodgey plugs when new. Try the old plugs if they worked fine. If its not that, replace the DFI module.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    interesting problem, so it only happend after the service. im thinking that one of the vacuum hoses must be cracked, prolly happend after it was disturbed.
    while the engine is running, spray some crc on the vacuum hoses, and if the revs increase you have a hole in it.
    Jun 2008
    Thumbs up thanx fellas
    cheers ay! I got a feeling its gotta be the dfi module. Coz everything else has been ruled out. Coz the old plugs gave the same problem. But thanx for that.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    big m's Avatar
    big m is offline FIGJAM
    vslll v6 2000 olympic series ute, 1997 pajero 3.5l
    Sep 2006
    nsw
    sorry if i sound like a bit of a tard but what and where is the dfi??
    Homer: "for once in my life someone is calling me sir without (your making a scene)"
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by big m View Post
    DFI is the block under the coil pack. NOt really sure what is does, but ut has wires going to each cylinder plug on the coil if that makes anysense.
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    i can safely say your issue will be spark related.
    check the coil pack, you will find there is one that is starting to die.
    i am the god of britany spears womanizer on just dance on the wii
    Doctor Bob's Avatar
    May 2004
    Quote Originally Posted by Tom_1569 View Post
    Direct Fire Ignition... its the module under the coils that controls them
    if you have tried coils etc try swapping this module.
    Rob
    Nov 2007
    I have seen injectors block after missfires when leads are on backwards. Its like the pressure created in the manifold blocks them up or something.
    If its there on acceleration but it will rev or cruise at a constant OK then it really sounds like injectors to me.
    VL EXEC
    Apr 2008
    mmmm.... have you checked the injectors or givin them a good flush?
    HONESTLY OFFICER, IT WAS CONSECUTIVE U TURNS..
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I would definately try another DFI first.
LinkBacks (?)
  1. 23-06-2008, 02:03 PM
  1. Mystery Noise
    By younglion in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2007, 01:47 PM
  2. Mystery box
    By Joe_222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2007, 09:18 PM
  3. Mystery Water
    By Kid_Random in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 01:50 PM
  4. Mystery Plug
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2007, 11:38 AM
  5. Mystery Cable
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 10:30 PM
