Results 1 to 3 of 3
Thread: before I get a wheel alignment...
    TWOJZ is offline Banned
    VL shagon ;)
    Apr 2008
    Adelaide!
    Default before I get a wheel alignment...
    is there anything else I could/should replace?
    all the front bushes have been replaced.
    will the top strut bearing plate thingo effect alignment?
    I guess I should replace the springs, if I'm planning on doing that in the future
    haha, anything else?
    thanks!
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    check the lower ball joint for movement, usually needs two people to check it, one to look at the joint and one to lift the wheel up and down.
    jack the car up so the wheel is just off the ground, get a lever bar under the tyre and lift the wheel up and down while the other person watches for movement in the joint
    because most suspension joints pick on them for causing camber problems when they have movement and they will usually tell you they are rooted when they arent just so they can make some money so it pays to see if they are being honest by checking it yourself first
    VL shagon ;)
    Apr 2008
    Adelaide!
    well, Pedders didn't say the ball joints were worn when they told me everything else was, which it wasn't, so maybe they are worn...
    haha
    just went and got new springs all around, and new rear shocks.
  1. Wheel alignment VE Omega
    By herkman in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-12-2006, 10:38 AM
  2. Wheel Alignment
    By Shounak in forum General
    Last Post: 29-10-2006, 06:55 PM
  3. Walkinshaw wheel alignment
    By damianison in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-09-2006, 11:33 PM
  4. re:vk black efi wheel alignment
    By VK1981 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-08-2006, 01:17 AM
  5. Wheel alignment
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2004, 02:49 PM
