Results 1 to 2 of 2
Thread: vn v8 diagram
    Aug 2008
    Default vn v8 diagram
    Hi, can any one help iam having prob with my vn v8 think i have the cacuum hoses installed incorrectly is there any wear on the net i can get a diagram?
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    did you mean vacuum hoses if you did of the top of my head and please correcrt me if i am wrong or have forgotten one is.
    there are two at the frount of the manifold the small one goes to the fuel reg the big one to the map sencer
    at the back there are two the real big one to the brake booster. then directly below that out of site and is hard to see is the one most people miss is a small one that goes to the vacum line that runs along the fire wall to the vac canster and to inside the car for the opperation of the air con and heater it enters near the heater hoses on the fire wall. then the other side of the heater hoses is another small one that when the heater is turned on opens a valve on the heater hose itself . i hope this helps
  1. VS wiring diagram
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2007, 04:38 PM
  2. Need VK Fan Wirring Diagram
    By NV_DIS_VH in forum Electrical Wiring / Questions
    Last Post: 16-01-2007, 08:35 PM
  3. I need a VT wiring Diagram
    By hardlyevolved in forum Electrical Wiring / Questions
    Last Post: 08-04-2006, 08:28 PM
  4. vn wiring diagram
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2006, 12:16 PM
  5. VS Wiring diagram
    By eags in forum Electrical Wiring / Questions
    Last Post: 21-03-2006, 08:01 PM
