Results 1 to 6 of 6
Thread: Piston Size Identification (help)
    vasrox is offline every bolt has a nut.....
    VH/SLE 308
    Jun 2005
    Question Piston Size Identification (help)
    Ive just stripped down the old 308 and came across this on the piston.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    hmm its a bit hard to tell from that dont know what brand of pistons they are they flat tops? or lightly dished? easiest way is to measure the bires or the piston if you got the right micrometers
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VH/SLE 308
    Jun 2005
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    thats what factory piston have once again impossible to tell really i dont think theres a standard for coding parts across every piston manufacturer. Best bet is to measure them or the bores
    VH/SLE 308
    Jun 2005
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    ok stock bore size is 4 inches or 101.6mm. if its 103mm thatd make it in my book 4.06 inches so that means its been bored out 60 thou (103.123mm) so mate i hope the bores are good and your micrometer is accurate because thats as big as you can go on them. I prefer to use micrometer in thou more accurate and you find that machining is all pretty much in inches and thou.
  1. Front calliper - piston boot refitting and sliding piston into bore
    By Project_Corty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2008, 09:37 AM
  2. Transmission Identification?
    By vasrox in forum The Pub
    Last Post: 28-08-2007, 05:48 PM
  3. Part identification
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-04-2007, 10:35 AM
  4. 202 Block identification
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-03-2007, 12:48 PM
  5. Piston size help?
    By traindriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-06-2006, 04:48 PM
