Results 1 to 8 of 8
Thread: help!! front disk rotors
    5ltr vr calais
    Aug 2008
    Angry help!! front disk rotors
    the front disk rotors on my vr will not budge any ideas how to remove them?
    '97 VS Commodore + '98 E36
    Apr 2005
    calipers off yea?
    your gunna get rid of the old rotors yea?
    then get out the good ol sledge hammer and smashed the baaaaast off.
    hit it then roatate it, hit then rotate, etc till it comes off.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, as above....give it a man go.
    Visit my Facebook page
    vr berlina
    Aug 2008
    as long as you're replacing them.....then as above. Just done mine last friday. New discs and I would assume you would/should be putting new pads in as well. Don't forget to take some fluid out of the brake reservoir before you push pistons back to refit calipers. May help to wire brush hub to make it easier for old discs to slide off + a bit of crc.
    good luck
    VE Commodore SS
    Sep 2007
    Grab one of the bolts that hold the caliper onto the caliper mount.
    It's a perfect fit for the 3 holes that are in the rotor towards the centre. Put it in one and screw it in til you see the rotor start to move off the hub. Take it out and put it in the next one. Keep going bit by bit (or use 2 bolts at the same time).
    The bolt pushes against the hub and the rotor will come off. Mine were both rusted tight!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Just use a decent hammer and spin the hub slowly and keep bashing away at the top edge as you spin and it will unfreeze it eventually, dont be afraid to give it a decent floggin.
    Reaper
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    big hammer,oxy ,carton of your bevrage of choice ..allways works for me
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    i used some piston puller thing and a rattle gun...worked fine with no damage to the rotors
  1. changing front rotors?
    By sik sv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2007, 10:51 AM
  2. Front rotors stuck
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2007, 06:41 PM
  3. Front rotors and shockies.
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2007, 11:11 PM
  4. VK Stock drum and disk setup to a VT disk setup
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 09:37 PM
  5. VS 95 wagon, diff / rear end disk - disk
    By digisol in forum Swap / Wanted to Buy / Trade
    Last Post: 27-11-2005, 06:05 PM
