Results 1 to 13 of 13
Thread: Diffs: minispools and backlash
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question Diffs: minispools and backlash
    I've got a VN s1 V6 auto with some backlash in the open-centred diff.
    I have a VR 5L live axle with a semi-working LSD (LS on street, open wheels on skidpan).
    I have a minispool sitting in my room that should suit either diff.
    Does backlash come from the gears or the diff centre? I don't know enough about it... what I was thinking is this: take my LSD rear axle from the VR and install it in the VN. Use the VN open-centre in the VR and put the minispool in that.
    Will I end up with the backlash still there? VN's done 500,000km if that gives an idea of the condition of the diff.
    Any thoughts appreciated
    Sam
    WTB: mulberry VN interior parts
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I know, that's why I have to swap diffs if I want a minispool in the 5L.
    VP Executive R-spec
    Jan 2005
    It's the main gears so the centre wont change it, you just need to tighten the gears up a bit
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I have absolutely no idea how to do that!
    Back to being unsure wtf to do with this minispool
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    put the spool in the v8 its fun i think the nut you are chaseing is under the flange for the tailshaft i may be wrong...
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Which nut is that? Also the front seal on the LSD in the VR has started to weep... it costs a ****load to get one of these things rebuilt doesn't it?
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    its under the flanges of the tailsharft you have to split the tailsharft from the diff to see it before i got myne rebuilt i did it up an it stoped the leak for a little while put the open wheel with the mini spool in the v8 and the lsd in the v6 well that what i would do but it dont mean im right
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    OK, so that nut can tighten the seal up a bit? Might have a crack at it.
    That's what I'm thinking at the moment mate but the only thing holding me back is that the open wheeler has some backlash and I don't want to end up with that in the V8 as the shift kit will make mincemeat of the diff gears.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by savage1987 View Post
    no, don't swing on that nut, if you tighten it to much the collapsable spacer that is used to set the pinion bearing preload can collapse slightly making your backlash problems worse.
    your best bet is to take it to a workshop and have em replace the seal and at the same time they might as well fit some gears and your open center which you can give em with the mini spool already fitted (assuming yo ucan remove the center from the VN and fit the mini spool into that yourself)
    Body by Holden, Soul by Brock
    the Legend will live forever
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    hes probably right my mechanic [not me] did it to mine with a rattle gun but i was getting it rebuilt in a cupple of weeks anyway
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    haha yeah I'll get it looked at professionally I think
  1. Vn Driveline Backlash
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2009, 05:32 PM
  2. diff backlash?
    By aza64 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2007, 10:24 PM
  3. Australian design rules and minispools
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2006, 04:03 PM
  4. backlash
    By n1tr0us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2006, 09:43 PM
  5. Price Of Minispools?
    By Evman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2005, 07:53 PM
