Results 1 to 7 of 7
Thread: strange knocking sound
    vt 2000 series 2
    Oct 2008
    Exclamation strange knocking sound
    hi guys,
    I own a 2000 vt series 2, i was wondering if you could help me.
    i was driving my car the ather day when i heard a knocking sound coming from the front of my car it didn't start until i was going over 60k's or more. the faster i went the worse it got, there is also some realy bad vibrations going through the car.
    Any ideas?
    rob
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like one of the pulleys or the water pump. With the engine off grab each pulley and give it a wobble to see which one moves.
    Visit my Facebook page
    VT Executive S2
    Sep 2008
    Perth, Western Australia
    i have a sound like that
    exact same car aswell
    except mine clunks when i turn corners
    not all the time
    just every now and then
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Quote Originally Posted by brendanwrestledabearonce View Post
    not all the time
    you should check your link arm bushes or maaaybeeee ball joints, yeah link arms!
    Nobody wants to play with me
    Feb 2008
    detonation maybe?? because usually if theres a knocking sound coming from the engine, thats not good, you might bend conrods and stuff. its caused by the early ignition of the fuel/air mixture. the exhaust gas in the cylinders is expanding trying to push the piston down but because of inertia or centrifugal forces...one of them lol....the piston still travels up, causing damage. it could be that, or it could be somthing else.
    Ossama Bin Laden >>>>>>>>>>> Hide n' Seek Champ since 2001
    A Toyota?
    Nov 2008
    If it's dependant on car speed rather than engine revs, then I'd be looking away from the engine. I know when I had a ****ed bottom end, the knock only got worse when my revs were up, totally independant on speed.
    VT spac super6
    Nov 2008
    Riverton sa
    they run duel knock sensors.. if it was pingin youd lose alot of power n the engine light would come on..
  1. knocking rattling sound
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2006, 05:21 PM
  2. Strange knocking noise
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 05:45 PM
  3. Strange knocking sound when cornering hard
    By zeep in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-10-2005, 11:37 AM
  4. Knocking Sound
    By davo2011 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-07-2005, 01:11 PM
  5. Knocking Sound From Crank Pulley
    By patto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-03-2004, 11:10 PM
